Hi all,
Bought a used Venstar T6800. Runs API 5. Firmware version is 4.08 (latest for this model).
Local API is on. Getting the following when running the simple http://192.168.1.5 (thermostat address):
{"api_ver":5,"type":"commercial"}
to test API ran the following: http://192.168.1.5/query/info and the response was
{"name":"HOME","mode":1,"state":0,"fan":1,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"holiday":0,"override":0,"overridetime":0,"forceunocc":0,"spacetemp":22.5,"heattemp":20.0,"cooltemp":29.0,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"setpointdelta":1.0,"availablemodes":2}
Perhaps someone will find it useful, but API did not respond at all when there was a space in the name. So the above shows that local API works.
My entry in the config is:
climate:
- platform: venstar
host: 192.168.1.5
ssl: false
timeout: 5
humidifier: false
The error I am getting is:
2019-09-12 23:17:51 ERROR (MainThread) [homeassistant.components.climate] venstar: Error on device update!
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 292, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 441, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/usr/src/homeassistant/homeassistant/components/venstar/climate.py", line 98, in update
info_success = self._client.update_info()
File "/usr/local/lib/python3.7/site-packages/venstarcolortouch/venstarcolortouch.py", line 140, in update_info
self.away = self.get_info("away")
File "/usr/local/lib/python3.7/site-packages/venstarcolortouch/venstarcolortouch.py", line 179, in get_info
return self._info[attr]
KeyError: 'away'
Any pointers on how to possibly fix this would be highly appreciated. I understand that the component wiki says it was tested with firmware 5 and possibly this ‘away’ variable exists there, but I was hoping that perhaps there is something I can do to make this work.
Thanks in advance!
