Ventilatiewarmtepomp met ESP32
Good evening technicians,
Hopefully this is in the right section of the community.
I have had a Nefit Ventiline VA/W 1.4C ventilation heat pump for 6 years, which includes a mechanical ventilation motor that is controlled by the Nefit electronics. A Nefit RF transmitter switch and an RF receiver are used for control, which is connected to the Nefit electronics with a cable.
I have been working with Home Assistant for 2 years now and would now like to control the mechanical ventilation via Home Assistant via an ESP32 print.
Now my question is, can I use the ESP32 to control this mechanical ventilation and if so what is the best solution? Do I have to solder 4 outputs to the 4 buttons of the transmitter switch or can I connect the ESP32 directly to the electronics in the Ventiline so that I can run the motor at different positions via the 4 outputs?
In the appendices there are a number of photos with more information about the components.
I’m curious if any of you are familiar with this or have already discovered this or whether it is possible.
You need to post in English, please.
