Hello. I have comfo 350 luxe and have had problems with
my CC Ease Controller (12V), which turns on and off every 60 seconds. Impossible to use and it shows the same numbers.
no controlling functions.
Can You recommend how to replace it or fix it. It is impossible to get it in Norway.
I use it for Zehnder Comfoair 350
Will new Comfosense C work with my Comfoair 350. thanks in advance
There are two versions of the ComfoSense controller āZehnder ComfoSense Cā and āZehnder ComfoSenseā. You have to install the second one, without the āCā. It has replaced the CC Ease Controller controller a few years ago but is fully compatible.
Just one comment. Price of this device is so high (~200 EUR) that you could set up Home Assistant on a RPi and some tablet that you would install in place of the Zehnder controller With a bit of wiring you could control the ventilation from HA.
Does anyone know if itās possible and how to change precision level (to show decimals) in wichersās script? I am getting no decimals while some of you show screens with more precise readings
HI, itās been a while, COVID and some health related problems prevented me to attend the forum.
I wrote in the meantime some code to read from the server and export the data to mqtt, but Iām not a great fan of it. As I have installed Homeassistant and there is no mode to pilot the serial port based ventilation system, Iām going to have a look at writing an HA module, but not having any expertise in the HA engine, it will probably take some time to develop.
I see you are using 3 boards. An ESP board, a max2323 rs323 to TTL? And what is the other one? I would like to make this myself, I have the same whr950 ventilation box.
