Hello community,
I am stuck with my automation to open the window automatically when the temperature is greater outside than inside and it is not raining right know or with a high propability later. It worked fine for a while with the predictions but when I implemented the ecowitt sensor it stopped in the choose section. Can somebody give me a hint how to solve this issue.
(code is a bit messy because of some different approaches i tried but it worked before the sensor change)
alias: Lüften Speicher auf
description: ""
- platform: time_pattern
seconds: /30
enabled: false
value_template: >-
{{ states('sensor.velux_sensor_temperature_sensor')|float >
states('sensor.gw1100a_v2_2_3_outdoor_temperature')|float + 1 }}
condition:
- "{{ now().month in [5, 6, 7, 8, 9] }}"
- choose:
- conditions:
- condition: numeric_state
entity_id: sensor.velux_sensor_temperature_sensor
below: sensor.gw1100a_v2_2_3_outdoor_temperature
sequence:
- delay: "00:15:00"
- stop: ""
- conditions:
- condition: or
conditions:
- type: is_precipitation_intensity
condition: device
device_id: a7d77cbd8ded9c7728498fce45f2c346
entity_id: sensor.gw1100a_v2_2_3_rain_rate
domain: sensor
above: 0
- condition: state
entity_id: sensor.openweathermap_forecast_precipitation_probability
state: ">70"
- condition: state
state: ">0"
sequence:
- service: notify.mobile_app_manu_handy
message: >-
Velux Fenster bleibt wegen Regen weiter geschlossen - {{
now().strftime("%H:%M")}}- Temp Speicher {{
states('sensor.velux_sensor_temperature_sensor', with_unit=True,
rounded=True) }} > Draußen {{
states('sensor.gw1100a_v2_2_3_outdoor_temperature',
with_unit=True, rounded=True) }}
title: Lüften - Speicher
- service: notify.mobile_app_sarina_s21
message: >-
Velux Fenster bleibt wegen Regen weiter geschlossen -- {{
- delay: "00:15:00"
- stop: ""
- conditions:
- condition: state
attribute: attribution
state: ">50"
- condition: state
state: <1
condition: device
domain: sensor
below: 0.1
enabled: true
- condition: state
state: "0"
sequence:
- device_id: f337c73c96feaac319fd4f52a3c88716
domain: cover
entity_id: cover.velux_window_roof_window
type: set_position
position: 20
message: >-
Velux Fenster wurde wegen Regen nur teilweise geöffnet - {{
message: >-
- service: media_player.play_media
entity_id: media_player.buro
media_content_id: >-
media-source://tts/google_translate?message=Temperature+info%3A+Window+in+the+attic+was+partially+opened
media_content_type: provider
metadata:
title: "Temperature info: Window in the attic was partially opened"
thumbnail: https://brands.home-assistant.io/_/google_translate/logo.png
media_class: app
children_media_class: null
navigateIds:
- media_content_type: app
media_content_id: media-source://tts
- media_content_type: provider
- conditions:
- type: is_value
condition: device
device_id: 066738ba1727c7478061c7c95afadc50
domain: sensor
below: 50
condition: device
domain: sensor
below: 0.1
enabled: false
- condition: state
state: <0
sequence:
domain: cover
type: set_position
position: 50
message: >-
Velux Fenster wurde geöffnet - {{ now().strftime("%H:%M")}}-
Temp Speicher {{
message: >-
Temp Speicher {{
media-source://tts/google_translate?message=Temperature+info%3A+Window+in+the+attic+was+opened
metadata:
title: "Temperature info: Window in the attic was opened"
media_class: app
navigateIds:
enabled: true
- repeat:
until:
sequence:
- delay:
hours: 0
minutes: 15
seconds: 0
milliseconds: 0
Thanks for your help and insight how to do it the right way
