Ver 50.2 Zwave Garage Door Issues (barrier?)
I been posting in the Configurations,Zwave area https://community.home-assistant.io/t/linear-ngdz00-4-garage-door/2136/283?u=penright
I had overcome the barrier. (pun intended :-)) exception class 66.
But since upgrading to 50.2, I can not get it to work. I thought SSH was being broken, but I had to go somewhere and finally booted.
I will boot a few more times, sometimes Zwave is funny in that way.
Meanwhile could someone look at the log here and tell me if I need to figure out what I am doing wrong or is this a bug?
https://hastebin.com/butazutali.sql
Here is the log after the second boot …
https://hastebin.com/qegivaduku.erl
I noticed it did not have some of the trace backs, so I thought I would try a third time.
Here is the log from the third reboot …
https://hastebin.com/anayafiyuw.erl
Here is the zwave log
2017-08-08 17:04:29.477 Detail, Node012, Query Stage Complete (Dynamic)
2017-08-08 17:04:29.477 Detail, Node012, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Configuration live=1
2017-08-08 17:04:29.477 Detail, Node012, QueryStage_Configuration
2017-08-08 17:04:29.477 Detail, Node012, QueryStage_Complete
2017-08-08 17:04:29.477 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2017-08-08 17:04:29.477 Warning, CheckCompletedNodeQueries all=1, deadFound=0 sleepingOnly=1
2017-08-08 17:04:29.477 Info,          Node query processing complete.
2017-08-08 17:04:29.477 Detail, Node012, Notification: NodeQueriesComplete
2017-08-08 17:04:29.483 Detail, contrlr, Notification: AllNodesQueried
2017-08-08 17:04:38.169 Detail, Node012,   Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x0c, 0x02, 0x98, 0x40, 0x25
2017-08-08 17:04:38.170 Info, Node012, Received SecurityCmd_NonceGet from node 12
2017-08-08 17:04:38.170 Info, NONCES: 0x47, 0x8d, 0x7a, 0xa0, 0x5d, 0x83, 0xf3, 0xea
2017-08-08 17:04:38.170 Info, NONCES: 0x28, 0x66, 0x21, 0x1b, 0xff, 0x37, 0x83, 0xd6
2017-08-08 17:04:38.170 Info, NONCES: 0x87, 0xc5, 0x66, 0xe4, 0x48, 0x5a, 0xce, 0xeb
2017-08-08 17:04:38.170 Info, NONCES: 0x12, 0xf3, 0x86, 0x16, 0x31, 0xa9, 0xe3, 0x59
2017-08-08 17:04:38.170 Info, NONCES: 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
2017-08-08 17:04:38.171 Info, NONCES: 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
2017-08-08 17:04:38.171 Info, Node012, Sending (Send) message (Callback ID=0x01, Expected Reply=0x00) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x0c, 0x0a, 0x98, 0x80, 0x12, 0xf3, 0x86, 0x16, 0x31, 0xa9, 0xe3, 0x59, 0x05, 0x01, 0xb4:
2017-08-08 17:04:38.180 Detail,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-08-08 17:04:38.180 Detail,   ZW_SEND_DATA delivered to Z-Wave stack
2017-08-08 17:04:38.196 Detail,   Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x02, 0xe8
2017-08-08 17:04:38.196 Detail,   ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2017-08-08 17:04:38.214 Detail, Node012,   Received: 0x01, 0x1d, 0x00, 0x04, 0x00, 0x0c, 0x17, 0x98, 0x81, 0x2d, 0xf0, 0x8d, 0x94, 0x98, 0x8c, 0xf0, 0xf3, 0xde, 0xba, 0x6e, 0x3c, 0x12, 0xb7, 0xc1, 0x14, 0x2d, 0x39, 0x36, 0xaf, 0xef, 0x13
2017-08-08 17:04:38.214 Info, Raw: 0x98, 0x81, 0x2d, 0xf0, 0x8d, 0x94, 0x98, 0x8c, 0xf0, 0xf3, 0xde, 0xba, 0x6e, 0x3c, 0x12, 0xb7, 0xc1, 0x14, 0x2d, 0x39, 0x36, 0xaf, 0xef, 0x13
2017-08-08 17:04:38.214 Detail, Node012, Decrypted Packet: 0x00, 0x66, 0x03, 0x00
2017-08-08 17:04:38.215 Info, Node012, ApplicationCommandHandler - Unhandled Command Class 0x66
2017-08-08 17:07:15.917 Detail, Node012,   Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x0c, 0x02, 0x98, 0x40, 0x25
2017-08-08 17:07:15.917 Info, Node012, Received SecurityCmd_NonceGet from node 12
2017-08-08 17:07:15.917 Info, NONCES: 0x47, 0x8d, 0x7a, 0xa0, 0x5d, 0x83, 0xf3, 0xea
2017-08-08 17:07:15.917 Info, NONCES: 0x28, 0x66, 0x21, 0x1b, 0xff, 0x37, 0x83, 0xd6
2017-08-08 17:07:15.917 Info, NONCES: 0x87, 0xc5, 0x66, 0xe4, 0x48, 0x5a, 0xce, 0xeb
2017-08-08 17:07:15.917 Info, NONCES: 0x12, 0xf3, 0x86, 0x16, 0x31, 0xa9, 0xe3, 0x59
2017-08-08 17:07:15.918 Info, NONCES: 0x11, 0x05, 0x75, 0x10, 0x3c, 0xf8, 0xe6, 0xd9
2017-08-08 17:07:15.918 Info, NONCES: 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
2017-08-08 17:07:15.918 Info, Node012, Sending (Send) message (Callback ID=0x01, Expected Reply=0x00) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x0c, 0x0a, 0x98, 0x80, 0x11, 0x05, 0x75, 0x10, 0x3c, 0xf8, 0xe6, 0xd9, 0x05, 0x01, 0x6d:
2017-08-08 17:07:15.927 Detail,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-08-08 17:07:15.927 Detail,   ZW_SEND_DATA delivered to Z-Wave stack
2017-08-08 17:07:15.943 Detail,   Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x02, 0xe8
2017-08-08 17:07:15.943 Detail,   ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2017-08-08 17:07:15.961 Detail, Node012,   Received: 0x01, 0x1d, 0x00, 0x04, 0x00, 0x0c, 0x17, 0x98, 0x81, 0xcc, 0xc1, 0xe4, 0x44, 0xef, 0xac, 0xc2, 0x1f, 0x68, 0x83, 0xd6, 0xb4, 0x11, 0x68, 0x73, 0x4d, 0x1d, 0xb7, 0x8e, 0x6c, 0xc6, 0x97
2017-08-08 17:07:15.961 Info, Raw: 0x98, 0x81, 0xcc, 0xc1, 0xe4, 0x44, 0xef, 0xac, 0xc2, 0x1f, 0x68, 0x83, 0xd6, 0xb4, 0x11, 0x68, 0x73, 0x4d, 0x1d, 0xb7, 0x8e, 0x6c, 0xc6, 0x97
2017-08-08 17:07:15.961 Detail, Node012, Decrypted Packet: 0x00, 0x66, 0x03, 0xff
2017-08-08 17:07:15.961 Info, Node012, ApplicationCommandHandler - Unhandled Command Class 0x66
Looks like the Garage Door thread figured it out. My bad and it was not a bug. Man I wish open zwave will publish their part of the barrier fix. Anyway sorry, and if this works then we will have a cheatsheet for hassbian images.
