After Updating to 2021.1.0 my zWave devices started acting sluggish and finally stopped functioning. Then, without touching anything, it works for a while again. I checked the Vera Controller and it’s fine. It shows the proper updated device information. Decided to bounce it anyway. It didn’t change the situation.
Checked the Home Assistant log and found several of these:
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 445, in _make_request
six.raise_from(e, None)
File "<string>", line 3, in raise_from
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 440, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.8/http/client.py", line 1347, in getresponse
response.begin()
File "/usr/local/lib/python3.8/http/client.py", line 307, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.8/http/client.py", line 268, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/local/lib/python3.8/socket.py", line 669, in readinto
return self._sock.recv_into(b)
socket.timeout: timed out
The tracebacks were all pretty similar:
File "/usr/src/homeassistant/homeassistant/core.py", line 1461, in catch_exceptions
await coro_or_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1480, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 593, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 664, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 630, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 699, in async_turn_off
await self.hass.async_add_executor_job(ft.partial(self.turn_off, **kwargs))
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/vera/light.py", line 84, in turn_off
self.vera_device.switch_off()
File "/usr/local/lib/python3.8/site-packages/pyvera/__init__.py", line 802, in switch_off
self.set_switch_state(0)
File "/usr/local/lib/python3.8/site-packages/pyvera/__init__.py", line 793, in set_switch_state
self.set_service_value(self.switch_service, "Target", "newTargetValue", state)
File "/usr/local/lib/python3.8/site-packages/pyvera/__init__.py", line 556, in set_service_value
result = self.vera_request(**payload)
File "/usr/local/lib/python3.8/site-packages/pyvera/__init__.py", line 537, in vera_request
return self.vera_controller.data_request(request_payload)
File "/usr/local/lib/python3.8/site-packages/pyvera/__init__.py", line 121, in data_request
response = requests.get(request_url, timeout=timeout, params=payload)
File "/usr/local/lib/python3.8/site-packages/requests/api.py", line 76, in get
return request('get', url, params=params, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 529, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPConnectionPool(host='192.xxx.xxx.xxx', port=3480): Read timed out. (read timeout=30)
Is this just isolated to my installs?
Here is my install info:
Version --> 2021.1.0
Installation Type --> Home Assistant OS
Development --> false
Supervisor --> true
Docker --> true
Virtual Environment --> false
Python Version --> 3.8.7
Operating System Family --> Linux
Operating System Version --> 5.4.84
CPU Architecture --> x86_64
Hass.io Host Operating System --> Home Assistant OS 5.9
Update Channel --> stable
Supervisor Version --> 2020.12.7
Docker Version --> 19.03.13
Disk Total --> 98.4 GB
Disk Used --> 46.1 GB
Healthy --> true
Supported --> true
Board --> ova
Supervisor API --> ok
Version API --> ok
