im running Vera zwave controller and integrated into HA.
in the last week i lost the connection to Vera.
ive tried to remove the Vera integration and re-configure it and got an error “Could not connect to controller with URL 192.168.14.100:3480”
i’ve tried another Vera controller with a different IP (yes, the IP is static for both controllers)
i’ve installed a fresh HA on another rpi 3B+ and getting the same error on both controllers.
Ok. And the sub-net is the same? 192.168.sub-net.xx? Have you changed router?
I don’t remember the set-up when I installed the integration, if you specify the port or not.
For me it works fine … still
