Vera Plus generic Zigbee devices HA
I have bought a few cheap Zigbee RGB bulbs.
They show up in Vera, and I can control them on or off.
I cannot change the color, probably because Vera does not have the right configuration files.
I want to switch over to HA, and connect my Vera, because it has Zwave and Zigbee support and some nice interfaces to connect to my tablet on the wall.
But will switching to HA also solve my RGB problems?
Can I control the RGB bulbs in HA, using the Zigbee antenna in Vera Plus?
Or do they need to work fine in Vera first before they work in HA?
Rob
Not possible
Yes.
Vera is hell with zibee (as well zwave)… although íf zwave works it is ok.
For zigbee I recommend deconz (just a usb stick) in homeassistant.
