Vera3 Controller - failure after upgrade
Hi, I have just ugraded my HA from 0.96.5 to 0.07.2. After the upgrade (I have done this twice) everything appears fine, however, I loose all connectivity to my Vera3 controller.
This controller is what I started home automation with several years ago and now only has about 5 or 6 devices on it that dont work with my new aeotec stick or Im to scared to move.
Has anyone else seen Vera controller failure after the most recent upgrades.
cheers
There seems to be an issue with 0.97.2 with the pyvera update.
There are comments in another thread that home assistant is no longer receiving updates from sensors however switches still work.
Although you say you have lost all connectivity. Still worth checking the link below and try rolling back to 0.97.1 and see if that helps
https://community.home-assistant.io/t/vera-plus-z-wave-hub-stops-updating-home-assistant-with-sensors-status/
Thanks Keele
I have already rolled back succesfully.
Hope this gets resolved. I guess like many others the vera is still in play due to the legacy devices it runs.
