I use a Vera Plus HUB. Recently I have been encountering errors using Home Assistant. I have added the Vera Hub via the integration. The error is reported as:
“requests.exceptions.ReadTimeout: HTTPConnectionPool(host=‘192.168.N.NNN’, port=3480): Read timed out. (read timeout=30)”
It is happening with Zwave lights and blinds. I previously did not have this issue and can’t understand why this is occurring. I will post the full log for this error below.
Any insight is very much appreciated.
-LeeTXJD
`Logger: homeassistant.components.automation.living_room_before_sunset
Source: helpers/script.py:501
integration: Automation (documentation, issues)
First occurred: May 27, 2024 at 7:45:04 PM (1 occurrences)
Last logged: May 27, 2024 at 7:45:04 PM
Living Room Before Sunset: Error executing script. Unexpected error for call_service at pos 1: HTTPConnectionPool(host='192.168.N.NNN', port=3480): Read timed out. (read timeout=30)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 501, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 736, in _async_call_service_step
response_data = await self._async_run_long_action(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 699, in _async_run_long_action
return await long_task
File "/usr/src/homeassistant/homeassistant/core.py", line 2738, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2779, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1000, in entity_service_call
raise result from None
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1605, in async_request_call
return await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1047, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/cover/__init__.py", line 419, in async_set_cover_position
await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/vera/cover.py", line 60, in set_cover_position
self.vera_device.set_level(kwargs.get(ATTR_POSITION))
File "/usr/local/lib/python3.12/site-packages/pyvera/__init__.py", line 1022, in set_level
self.set_service_value(
File "/usr/local/lib/python3.12/site-packages/pyvera/__init__.py", line 561, in set_service_value
result = self.vera_request(**payload)
File "/usr/local/lib/python3.12/site-packages/pyvera/__init__.py", line 542, in vera_request
return self.vera_controller.data_request(request_payload)
File "/usr/local/lib/python3.12/site-packages/pyvera/__init__.py", line 121, in data_request
response = requests.get(request_url, timeout=timeout, params=payload)
File "/usr/local/lib/python3.12/site-packages/requests/api.py", line 73, in get
return request("get", url, params=params, **kwargs)
File "/usr/local/lib/python3.12/site-packages/requests/api.py", line 59, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 589, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 703, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.12/site-packages/requests/adapters.py", line 532, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPConnectionPool(host='192.168.N.NNN', port=3480): Read timed out. (read timeout=30)`
