Does anyone know how to enable Verbose logging when using NR as an add-on?
Thanks.
Thanks.
Inside config/nodered
folder you will find a file called settings.js
. Set the log level according to this
https://nodered.org/docs/user-guide/runtime/logging
Thanks, so this worked and I can view the log in the add-on page itself. The log however is only 1 page long.
Is there a separate directory that shows the entire log?
Thanks.
