I’ve just started out creating automations for my brand new Home Assistant installation. I have a Sensibo Sky heat pump control that I wish to automate day-time and night-time temperature reduction. I’ve tested it a few days now, and I’m having problems with the temperature not necessarily being set correctly. Home Assistant reports back that the automations have run correctly (When clicking the automation, it says “Last triggered: X minutes/hours ago”). But still the temperature is not set correctly. If I manually trigger the automation, it sets the temperature as it should.
I wonder if it could have something to do with IR transmissions being corrupted for some reason. How can I get Home Assistant to verify that an automation has been carried out successfully? Let’s say I wanted the automation to detect if the temperature hadn’t been set on the first attempt, and if so, attempt to set it again. And keep doing this before finally sending me a notification if it fails after X retries. Is this possible?
