Dear all,
I am new to Homematic and just bought the HmIP-RFUSB stick. The RasperryMatic installation went well. I chose the Express option for security settings and accordingly, authentification is required. I enabled the
- Homematic XML-RPC API
- Remote Homematic-Script API
and opened ports 42010 and 443 in the RaspberryMatic firewall.
So I installed Homematic (IP) Local. During setup, I enabled TLS and also chose “Verify TLS” (I think this is the verify_tls parameter). Now setup fails when I ask for the verification, but succeeds, when I do not tick the verification option (still enabling TLS).
Is this normal? Do I have to change other settings in RaspberryMatic? I tried to play around with the HTTPS option, but it makes no difference.
And - most important - am I right so far, not opening unnecessary ports or APIs?
This is the log:
024-04-21 20:13:07.557 ERROR (MainThread) [hahomematic.client.xml_rpc] SSLError on temporary_instance-HmIP-RF: (1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self-signed certificate (_ssl.c:1000)')
2024-04-21 20:13:07.557 WARNING (MainThread) [hahomematic.central] SSLError on temporary_instance-HmIP-RF: (1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self-signed certificate (_ssl.c:1000)')
2024-04-21 20:14:39.222 ERROR (MainThread) [hahomematic.client.json_rpc] GET_ALL_SYSTEM_VARIABLES failed: ClientConnectorError [(ConnectionKey(host='de838cd8-raspberrymatic', port=443, is_ssl=True, ssl=<ssl.SSLContext object at 0x7f80be8aa650>, proxy=None, proxy_auth=None, proxy_headers_hash=xxxx), ConnectionRefusedError(111, "Connect call failed ('172.30.33.2', 443)"))]
2024-04-21 20:14:39.229 ERROR (MainThread) [hahomematic.client.json_rpc] GET_ALL_PROGRAMS failed: ClientConnectorError [(ConnectionKey(host='de838cd8-raspberrymatic', port=443, is_ssl=True, ssl=<ssl.SSLContext object at 0x7f80be8aa650>, proxy=None, proxy_auth=None, proxy_headers_hash=xxxx), ConnectionRefusedError(111, "Connect call failed ('172.30.33.2', 443)"))]
2024-04-21 20:14:39.671 ERROR (MainThread) [hahomematic.client.xml_rpc] OSError on RaspberryMatic (lokal)-HmIP-RF: (111, 'Connection refused')
2024-04-21 20:14:39.671 WARNING (MainThread) [hahomematic.client] PROXY_DE_INIT failed: NoConnection [OSError on RaspberryMatic (lokal)-HmIP-RF: (111, 'Connection refused')] Unable to de-initialize proxy for RaspberryMatic (lokal)-HmIP-RF
2024-04-21 20:14:39.677 ERROR (MainThread) [hahomematic.client.json_rpc] GET_ALL_DEVICE_DATA for HmIP-RF failed: ClientConnectorError [(ConnectionKey(host='de838cd8-raspberrymatic', port=443, is_ssl=True, ssl=<ssl.SSLContext object at 0x7f80be8aa650>, proxy=None, proxy_auth=None, proxy_headers_hash=xxx), ConnectionRefusedError(111, "Connect call failed ('172.30.33.2', 443)"))]
2024-04-21 20:15:05.492 ERROR (MainThread) [hahomematic.client.json_rpc] GET_ALL_SYSTEM_VARIABLES failed: ClientException [POST method 'Session.login' failed: service not available]
2024-04-21 20:15:05.827 ERROR (MainThread) [hahomematic.client.json_rpc] GET_ALL_PROGRAMS failed: ClientException [POST method 'Session.login' failed: service not available]
2024-04-21 20:16:02.338 WARNING (MainThread) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: <html>
<head><title>503 Service Temporarily Unavailable</title></head>
<body>
<center><h1>503 Service Temporarily Unavailable</h1></center>
<hr><center>nginx</center>
</body>
</html>
2024-04-21 20:16:03.002 ERROR (MainThread) [hahomematic.client.xml_rpc] SSLError on temporary_instance-HmIP-RF: (1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self-signed certificate (_ssl.c:1000)')
2024-04-21 20:16:03.002 WARNING (MainThread) [hahomematic.central] SSLError on temporary_instance-HmIP-RF: (1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self-signed certificate (_ssl.c:1000)')
2024-04-21 20:16:27.272 ERROR (MainThread) [hahomematic.client.xml_rpc] SSLError on temporary_instance-HmIP-RF: (1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self-signed certificate (_ssl.c:1000)')
2024-04-21 20:16:27.272 WARNING (MainThread) [hahomematic.central] SSLError on temporary_instance-HmIP-RF: (1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self-signed certificate (_ssl.c:1000)')
2024-04-21 20:17:41.895 WARNING (MainThread) [hahomematic.client] PROXY_DE_INIT failed: NoConnection [SSLError on RaspberryMatic (lokal)-HmIP-RF: (8, 'EOF occurred in violation of protocol (_ssl.c:2406)')] Unable to de-initialize proxy for RaspberryMatic (lokal)-HmIP-RF
Is says something about certificates - do I have to create something?
This is normal. The default self signed certificate from your CCU cannot be verified by HA. Just disable verify tls and you are done.
@SukramJ Thank you! Does this mean TLS itself should be deactivated, or is just the check not working?
The check is working as expected.
TLS can be used, if you like it.
