Im trying to have the state of my Verisure Alarm to control lights in the entrance. But Im struggling
I want the automation to be triggered if the state is changing from Armed home / Armed away to Disarmed
I also want it to only work when the sun is below the horizon.
The light is a Philips Hue light.
The automation is working when I trigger it manually (so it seems like I have the lights ok), but it will not trigger by changing the state of the alarm. here is “code”
- action:
- alias: ''
brightness: 256
rgb_color:
- 255
- 197
- 100
entity_id: light.ball
service: light.turn_on
- delay: 00:02:00
- alias: ''
data: {}
service: light.turn_off
alias: 'Lys Gang etter sunset '
condition:
- after: sunset
before: sunrise
condition: sun
- entity_id: alarm_control_panel.trollkleiva_alarm
platform: state
to: Disarmed
platform: state
to: Disarmed
Take a look at the documentation for conditions. This bit is wrong. You need to have multiple conditions.
condition:
condition: or # 'when dark' condition: either after sunset or before sunrise
conditions:
- condition: sun
after: sunset
- condition: sun
before: sunrise
Check out the documentation:
Sunset to Sunrise will not work because it crosses the reset. Days reset at midnight. So anything after sunset does not equal before sunrise. You want to write your condition based on before sunrise OR after sunset.
before sunrise = 0 to sunrise. after sunset = sunset to 24 (or midnight).
I did make the changes to the condition, but still the same problem.
I also tried the same by taking the condition completely away and only have the trigger and the action. Still not working. seems like the error has to do with the the Verisure part (since the light (action) works when triggered manually from the web interface.
