Verisure and Homekit - magnetic sensors (binary_sensor) not responding
I yesterday moved to the new Verisure integration. Everything has worked and is working as expected in HA. However, my shock sensor detectors that work fine in HA are not available in Homekit. I can see them in Homekit but they do not respond. I verified HA by opening a door to see that it did change state, which it did. The other Verisure entities work in both HA and Homekit.
Has anyone else seen the same or can anyone offer an explanation? I could technically have misspelled something but it is not likely that I misspelled all four entities.
I have the exact same problem. Everything has been working smothly untill the new changes to verisure come around. allso my setup works with the normal homeassistant but not homekit.
