I’ve just installed the Verisure integration. Works great. However I would like to send push notifications to my phone when a binary sensor in the system triggers.
But it seems like the Verisure integration “misses” the door opening if it’s done fast (due to the 1 min polling rate). Works perfectly fine if I keep the door open for > ~1 min.
I understand the problem. Is there any chance this can be worked around? Or is the Verisure API limited so it cannot be done? In the Verisure app the door opening can be seen.
I am thinking of the API at least provides a date for the latest door close perhaps at least that could be seen in Home Assistant.
/ Henrik
