The verisure app now show door / Window sensor: Locked / open
Would it be possible to get the same info in homeassistant
As I’ve understood it, the component reads from the web page which doesn’t seem to expose the door / window sensor (yet).
But I would also like to have this, very much.
/R
Yes this would be great.
talked to Verisure today. They said they will most likely add the feature to the webportal as well, but did not have a ETA.
So I guess cross our fingers for it to happend quickly
Any updates on the Verisure door sensors?
The only issue is that it is still a polling implementation. So no real time info
door window sensor is added to the latest release of HA. But as Robban sais it is polling, so it can take a while before HA notice the change, and a quick open-close can be missed.
Is the docs up to date?
Is it door_window: 1
I should add in the config?
The docks was no up to date, had forgot about that, they are updated now but it may take a while before they are published.
The door window sensor is enabled by default, and can be disabled by: door_window: 0
Ahhhh…
Recently I started using “default_view” and totally forgot about that.
Please assist
My door sensors aint showing up everything else is
Do you see anything in the log?
hey, my misstake it shows in HA but homebridge cant se it, want the door sensors to be vissible from the Home app on IOS.
Ok, then I guess the issue is in homebridge. I think it would be best if you create a new post with homebrigde in the topic.
