Okay, another topic from me. Hope you don’t find me annoying ;).
When I have added the verdure module, typed in the correct username and password, used the correct spacing for the yams file. I still get these errors:
17-01-29 13:19:51 ERROR (Thread-6) [homeassistant.components.verisure] Could not log in to verisure mypages, HTTPSConnectionPool(host='mypages.verisure.com', port=443): Read timed out. (read timeout=10)
17-01-29 13:19:51 ERROR (MainThread) [homeassistant.bootstrap] component verisure failed to initialize
Why is this and is there any way to fix it? Do I need to include quotes around my username and password in the yaml file? Here is the yaml btw:
verisure:
username: REMOVED
password: REMOVED
Thing is, it worked earlier, exactly with this configuration.
Ok, here’s the thing. When HA has been alive for some time (around 10 minutes or more), I get this error message:
homeassistant.components.verisure:Caught connection error HTTPSConnectionPool(host='mypages.verisure.com', port=443): Max retries exceeded with url: /settings/smartplug (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x6f6b7d50>: Failed to establish a new connection: [Errno 110] Connection timed out',)), tries to reconnect
Is this anything to worry about?
After I send any message to verisure using HA it doesn’t really go through to the other end and no visible change can be seen at the smart-plug.
