Have anyone been able to connect to Verisure components in Norway.
I have tried but can’t connect
It works like it should here. What’s the problem?
What kind of installation do you have? Do you have Verisure subscription or can you use VBox Micro?
I just bought a house with Verisure equipment installed (fire alarm, movement sensor etc), but I haven’t bought any subscription. Trying to research if it’s possible to use the sensors without
I believe you need a subscription, at least for the existing component.
I have added the component into the config yaml file, but get an error after restarting Hassio. After inspecting the log file, I get this:
2019-10-13 10:02:25 ERROR (SyncWorker_1) [homeassistant.components.verisure] Could not log in to verisure, Invalid response, status code: 401 - Data: {“errorGroup”:“UNAUTHORIZED”,“errorCode”:“AUT_00004”,“errorMessage”:“Invalid username/password/authentication method combination”}
I’ve used the same username/password settings I currently use on MyVerisure app (I’m in the UK).
Any ideas?
Hi there,
same for me. Any idea to solve the issue?
I’m from Italy.
Many thanks
Suddenly this has started to happen to me too!
It has worked very well for about 2 years, but now I keep getting this message. And nothing happens in my locks.
After a HA restart it works again for a while. I don’t know for how long. Could it be some kind of certificate/token that has to be refreshed? I’m on HA Core 0.106.2.
I’m getting the same error too…
Did anyone manage to resolve this?
Please? There must be some smart people out there that can help? My integration starts failing about 7 hours after HA restart. Then it fills up the log with (2000 times since 6 o’clock this morning):
2020-08-24 06:03:47 ERROR (SyncWorker_53) [homeassistant.components.verisure] Could not read overview, Invalid response, status code: 401 - Data: {"errorGroup":"UNAUTHORIZED","errorCode":"AUT_00011","errorMessage":"Invalid session cookie"}
2020-08-24 06:03:47 ERROR (MainThread) [homeassistant.helpers.entity] Update for lock.hoveddor fails
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 263, in async_update_ha_state
await self.async_device_update()
HA core 0.114.3, Intel NUC
What could be wrong?
Has anyone done any work on making a 100% local integration, without being dependent on the verisure web?
