Verisure not working with Home Assistant on new Verisure install in France and Spain
Very dissapointed because Verisure component is not compatible with new verisure installations on france.
I guess is because they have changed the architecture, now is not connecting to ‘https://mypages.verisure.com/login.html
here in France it connects trough: ‘https://customers.securitasdirect.fr/fr/login/FR
And I think in Spain is ‘https://customers.securitasdirect.es/
Has anyone found a solution for this or a way to integrate new verisure installations in EU on to Home Assistant?
You fix this?
I get this errors:
2017-10-17 20:14:54 ERROR (MainThread) [homeassistant.setup] Error during setup of component verisure
  File "/usr/src/app/homeassistant/setup.py", line 194, in _async_setup_component
    component.setup, hass, processed_config)
  File "/usr/local/lib/python3.6/asyncio/futures.py", line 332, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/local/lib/python3.6/asyncio/tasks.py", line 250, in _wakeup
    future.result()
  File "/usr/local/lib/python3.6/asyncio/futures.py", line 245, in result
    raise self._exception
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/src/app/homeassistant/components/verisure.py", line 69, in setup
    if not HUB.login():
  File "/usr/src/app/homeassistant/components/verisure.py", line 119, in login
    self.session.login()
  File "/usr/local/lib/python3.6/site-packages/verisure/session.py", line 90, in login
    self._vid = json.loads(response.text)['cookie']
KeyError: 'cookie'
NO, I think the Verisure component only work for US Clients.
I live in Spain and have the Verisure alarm system, cameras, climate Sentinal and window/ door sensors.
I have had the alarm panel integrated for quite some time through the securitas_direct custom component but can’t get the rest of the devices working.
Today I had a play around and now at least get the Configure pop up which is promising.
There are two apps here in Spain. I am on the older app so maybe when they move us over to the new one it might be possible to integrate this :slight_smile:
Hello @ursus69 any update for Verisure France integration ?
I guess the issue is still not fixed :frowning:
i tried and still the same integeation error.
bref. c’est pas cool :wink:
I’m with Verisure in Spain and I can’t get the authentication to work. My username is a number and not an email address. Not sure if anyone has had any luck with this?
