Verisure (Securitas Direct) Integration Experience
Probably getting Verisure in Sweden within a few weeks.
How is your experience with the integration?
  • Is it stable?
  • How ofter does the API break due to Verisure updates?
  • Have you been penalised due to accessing their API too much (or outside app)?
  • What kind of pheriperals can you retrieve data from?
I wish to trigger automations based on larm status, and read sensor data, such as temperature status, and motion sensor data.
Much thanks,
Br,
Tim
here it is.
esphome:
platform: ESP32
board: nodemcu-32s
Enable logging
logger:
web_server:
port: 80
Enable Home Assistant API
api:
ota:
password: “xxx”
wifi:
ssid: “MOVISTAR_xxx”
password: “xxx”
manual_ip:
# Set this to the IP of the ESP
static_ip: 192…x.x.x
# Set this to the IP address of the router. Often ends with .1
gateway: 192.168.0.1
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
Enable fallback hotspot (captive portal) in case wifi connection fails
ap:
ssid: “Consumo-Agua-General”
password: “xxxx”
captive_portal:
Example configuration entry
  • platform: pulse_counter
    pin: 2
    name: “consumo Agua general L/min”
    update_interval : 60s
    filters:
    • lambda: return (x / 373.0);
      unit_of_measurement: “L/min”
    pin: 2
    name: “consumo Agua general L/hora”
    filters:
    • lambda: return (x / 373.0) * 60.0;
      unit_of_measurement: “L/Hr”
    name: “consumo agua litros”
    pin: 2
    #number: GPIO2
    #mode: INPUT_PULLUP
    icon: “mdi:water”
    filters:
      #- lambda: return x * (1/140.0);
    se ha calibrado con cubo de 5 litros = 1864 pulsos
    1 litro = 373 pulsos
    unit_of_measurement: “Litros”
