Version integration poll frequency setting?
Does anyone know if of a way to adjust how often the Version integration checks for updates?
I’m seeing lots of traffic polling the docker registry, polling 4 times… waits 5 minutes, then polls 4 times again then repeats.
I’m really not interested in checking every 5 minutes, so is there a way to limit this to maybe once a day?
The 5-minute interval is hard-coded here:
May I ask for an adjustable setting on the setup screen maybe? Where you select the polled source or some other way to override the hardcoded value
You’re welcome to ask (that’s the purpose of a Feature Request) but you should know I am not the Version integration’s author (nor a python software developer). I just wanted to confirm your observation about the polling interval (and that it’s not currently adjustable anywhere except in the source code).
Thanks!
I hope they watch this. I visited the hithub page before your initial reply, and their option for feature request issues sent me here.
Thank you @123 , as a temporary workaround, i’m patching this file to modify the interval. Hopefully a more elegant solution will be implemented at some point.
would like to lower it here aswel it shows up in dns logs overly
My temporary solution is to modify /usr/lib/python3.9/site/packages/homeasistant/components/version/const.py
Find the line that reads minutes=5 and change that 5 to your desired interval in minutes
If you’re running this in docker, you can easily patch this file on startup.
