Version Sensor - source: hassio constantly changes beween 2021.3.4 and 2021.4.4
Version Sensor - source: hassio constantly changes beween 2021.3.4 and 2021.4.4 these days.
This triggers a full snapshot automation every hour on my RP3 :-/
hassio
Same here! But funnily, it’s not as often as in your case…
problem still there in version 2021.4.5
(constantly changes between 2021.4.4 and 2021.4.5)
I have the same issue. Please add logs to this issue as if I am the only one it will never be solved
Have same issue here as well. latest version jumps back to 3.4 when it is 4.5 is the latest.
https://version.home-assistant.io/stable.json
