When I set up a vertical view, the column of cards is placed in the center of the dashboard. Is there a way to left-justify this column, so it’s immediately to the right of the sidebar?
That will do the trick! Thank you.
I’m still struggling. I’ve installed layout-card from HACS, and I’ve got my test dashboard saved to a .yaml file. To recap, what I need is all my cards to be vertically stacked, in one column immediately to the right of the sidebar, not in the middle of the display.
configuration.yaml:
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
lovelace:
mode: storage
dashboards:
lovelace-yaml:
mode: yaml
title: Test
icon: mdi:home
show_in_sidebar: true
filename: dashboard1.yaml
Here’s dashboard1.yaml, only the first card is listed, there are 6 more, not listed for brevity:
title: Test
- theme: Backend-selected
path: home
title: Home
cards:
- show_current: true
show_forecast: true
type: weather-forecast
entity: weather.kocf
forecast_type: hourly
- type: entities
entities:
- entity: sensor.lacrosse_tx141thbv2_0_124_temperature
- entity: sensor.prologue_th_9_1_71_temperature
- entity: sensor.lacrosse_tx141thbv2_0_124_humidity
unit_of_measurement: ' %'
- entity: sensor.acurite_5n1_a_290_wind_speed
unit_of_measurement: mph
style: ''
card_mod:
style: |
ha-card {
font-size: 25px;
title: Outdoors
