Vertical Pill Card (like Minimalist UI) using HA Card only. Having problem with radiant color
Hello everyone,
I’ve hit a good stride making my own version of the Vertical Pill Card and I’ve been working on something fancy for my Halloween outdoor light scenes, but as you can see from the image below, there is a tiny bit of bright color at the bottom of the pill (or top on the second scene). Can any of you me understand why this is happening? I’ve attempted to rotate the color, but then the color ends up on the opposite side. Also, in looking closer, the color run over is happening at the top and the bottom, but it’s harder to see on the side opposite of the purple.
As an aside, I’d like to remove the icon background circle from both of the “activated” Halloween scenes as well if anyone knows how. I’ve attempted a few things, but it hasn’t worked yet.
Screenshot 2024-10-08 at 12.38.17 PM
Here is the full code of the card. Please advise! Thank you!
type: horizontal-stack
cards:
    primary: Lights
    secondary: null
    icon: mdi:lightbulb-group-off
    layout: vertical
    icon_color: yellow
    tap_action:
      action: perform-action
      perform_action: script.turn_off_all_downstairs_lights
      target: {}
    hold_action:
      action: none
    double_tap_action:
      action: none
    card_mod:
      style: |
        ha-card {
          --card-primary-font-size: .9rem;
          width: 60px;
          border-radius: 30px;
          height: 62px !important;
          padding: 29px 0 0 1px;
          box-shadow: 0px 2px 4px 0px #333333;
        :host {
          --mush-icon-size: 50px;
        {% if states('light.cabinet_lights') == 'on' %}
            ha-card {
              height: 100px !important;
              padding: 0 0 9px 0;
            ha-state-icon {
              --card-mod-icon: mdi:lightbulb-group
            ha-tile-icon {
            --tile-color: yellow;
            {% else %}
            {% endif %}
    primary: Bed
    secondary: null
    icon: mdi:bed
    layout: vertical
    icon_color: green
    tap_action:
      perform_action: input_boolean.toggle
        entity_id: input_boolean.goodnight
    card_mod:
      style: |
        ha-card {
          --card-primary-font-size: 1rem;
          width: 60px;
          padding: 29px 0 0 0;
        :host {
        {% if states('input_boolean.goodnight') == 'on' %}
            ha-card {
              padding: 0 0 9px 0;
        {% else %}
        {% endif %}
    primary: Oct
    secondary: null
    icon: mdi:halloween
    layout: vertical
    icon_color: orange
    tap_action:
        entity_id: input_boolean.halloween
    card_mod:
      style: |
        ha-card {
          width: 60px;
        :host {
        {% if states('input_boolean.halloween') == 'on' %}
            ha-card {
              padding: 0 0 9px 0;
              background: linear-gradient(0deg, rgba(75,0,130,1) 0%, rgba(255,152,0,1) 60%);
              --primary-text-color: black;
              --card-primary-color: black;
          ha-state-icon {
            color: black;
        {% else %}
        {% endif %}
    primary: Oct
    secondary: null
    icon: mdi:candy
    layout: vertical
    icon_color: purple
    tap_action:
        entity_id: input_boolean.halloween_2
    card_mod:
      style: |
        ha-card {
          width: 60px;
        :host {
        {% if states('input_boolean.halloween_2') == 'on' %}
            ha-card {
              padding: 0 0 9px 0;
              background: linear-gradient(0deg, rgba(239,255,0,1) 10%, rgba(29,255,0,1) 27%, rgba(75,0,130,1) 45%);
            ha-state-icon {
              color: black;
        {% else %}
        {% endif %}
    primary: TBD
    secondary: null
    icon: mdi:ab-testing
    layout: vertical
    icon_color: blue
    card_mod:
      style: |
        ha-card {
          width: 60px;
        :host {
Figured it out. Remove the border with
ha-card {
border: none;
