Vertical Slider
Hi. im looking for vertical slider, at the moment i found 3 but none of them work for i what want.
3 that i found.
works best for shutters.
this one works, but i cant put the numeric state and also i cant name it
this one i can manage to work, i tried HACS install, and manual install, and doesnt work with a input_number value.
im making a DMX control throw MQTT, its working but i want vertical slider that i can name, and show numeric state fo the slider.
if anyone have any hidden vertical slider ahhahah
thanks!
What kind of vertical slider are you looking for?
If you go to Settings > Helpers and create/select your input_number.your_entity. Here you can change the display to a slider or field.
Then you can use this in an entities card. See: Entities card - Home Assistant
If you are using yaml in stead of the UI you could add this to your dashboard:
- type: entities
  entities:
  - entity: input_number.your_entity
    name: "Sliding al them ways"
    icon: mdi:slide
    tap_action:
      action: none
i currently have slider, but from left to right
i want them to be from up and down.
i put the code you send me, but it doesnt work, maybe im missing something.
im trying to do a mixer card, something like this but with name and values.
this is a horizontal stack with this code in it.
type: custom:my-slider-v2
entity: input_number.dmx_dimmer
vertical: true
show_name: true
showMin: true
showMax: true
sliderMin: 0
styles:
card:
- height: 200px
- width: 70px
track:
- background: |
if (entity.state == “off”) return “red”;
else return “purple”;
Those look great!
How can this be achieved?
yip, I’d be interested in how you did this as well… Looks fantastic
As for 04.25 :
Upper controls - GitHub - tolnai/hacs_cover_slider: Slider cover card for Home Assistant
Bottom - standard HA card
Covers are my own DIY.
Each slider is for separate entity, no scripts or automations.
At least for a while :wink:
Yet another great looking implementation!
I see that these are for cover entities though… any chance they’d be able to be used for something like lights?
Oh, sorry!
I was so happy to find just something and didn’t notice a topic subject.
By the way…
I think there’s a real possibility to translate cover’s action calls into calls for yuour lights. Something like MQTT proxy.
As a draft crazy idea:
create (define in configuration.yaml) an MQTT cover, define all topics for state, position etc. (open=on, close=off, position=brightness) , then create MQTT sensors on the same command topics as in cover and then create an automation where translate state changes into MQTT calls.
Or, even simpler - when define a MQTT cover - assign to it apropriate topics a same names as your light have. Really I don’t know is this a legal way for HA.
of course, all this is for the case if your light supports MQTT.
just 1st googling:
You be better off simply modifying the CSS to rotate the sliders within a card using:
transform: rotate(90deg) or
This card and direction: bottom-top
type: horizontal-stack
cards:
  - type: custom:slider-button-card
    entity: light.xxxx
    slider:
      background: gradient
      use_state_color: true
    action_button:
      mode: custom
      show: true
      tap_action:
        action: toggle
    icon:
      show: false
      use_state_color: false
    entity: light.xxxx
    slider:
    action_button:
      mode: custom
      show: true
      tap_action:
        action: toggle
    icon:
      show: false
      icon: ""
Width, color, info and more can be customized
unfortunately, I’m not very good in CSS. MQTT is much more familiar to me
I agree it is the more correct way.
And thank for the link.
Will try thic card too. Maybe it will look better.
No worries, all suggestion should be considered.
I mean… sure, kinda?
also, doing the transform doesn’t work on finger tracking. You still need to swipe lef/right to adjust the transformed element
Well yeah it needs more than one line of code. What’s your point?
That is why I also suggested the slider-button
that “simply modifying the CSS to rotate the sliders within a card using transform” is not the sought-after solution here.
Thanks for your input
In case you didn’t think rotate wouldn’t work with additional code. A rough example…
type: custom:layout-card
layout_type: custom:grid-layout
layout:
  grid-template-columns: 1fr 1fr 1fr
  margin: 0px 0px 0px 0px
cards:
  - type: entities
    entities:
      - type: custom:slider-entity-row
        entity: light.night_stand
        card_mod:
          style:
            hui-generic-entity-row $: |
              .pointer {
                display: none;
              ha-slider{
                 --_inactive-track-shape: var(--md-slider-inactive-track-shape, var(--md-sys-shape-corner-full, 10px))!important;
                 --_active-track-shape: var(--md-slider-inactive-track-shape, var(--md-sys-shape-corner-full, 10px))!important;
                 transform: rotate(-90deg);
                 margin-top: 100px;
                 --_inactive-track-height: 50px ;
                 --_active-track-height: 50px ;
                 --md-slider-handle-height: 28px ;
                 --md-slider-handle-width: 12px ;
                 --_label-container-color: transparent ;
                 --_label-text-color: transparent ;
                 --_active-track-color: {{"#%02x%02x%02x" %
              state_attr(config.entity,"rgb_color") }} ;
                 --_inactive-track-color: grey ;
                 --md-slider-handle-color: dodgerblue;
              ha-slider:after {
                content: "Night Stand";
                transform: rotate(90deg);
                width: 70px;
                position: absolute;
                right: 70px;
                top: 6px;
                font-size: 10px;
    card_mod:
      style: |
        ha-card {
          height: 150px !important;
          width: 120px;
          background: transparent;
          border: none;
  - type: entities
    entities:
        entity: light.tv_lightstrip
        card_mod:
          style:
              .pointer {
                display: none;
              ha-slider{
                 margin-top: 100px;
              ha-slider:after {
                content: "TV Lightstrip";
                width: 70px;
                position: absolute;
                right: 70px;
                top: 6px;
                font-size: 10px;
    card_mod:
      style: |
        ha-card {
          height: 125px !important;
          width: 100px;
          border: none;
          margin-left: -80px !important;
  - type: entities
    entities:
        entity: light.pc_lights
        card_mod:
          style:
              .pointer {
                display: none;
              ha-slider{
                 margin-top: 100px;
              ha-slider:after {
                content: "PC Lights";
                width: 70px;
                position: absolute;
                right: 70px;
                top: 15px;
                font-size: 10px;
    card_mod:
      style: |
        ha-card {
          width: 100px;
          border: none;
          margin-left: -160px !important;
An outside of the box solution…
cards:
  - features:
      - type: custom:service-call
        entries:
          - type: slider
            unit_of_measurement: "%"
            value_attribute: brightness
            tap_action:
              action: perform-action
              perform_action: light.turn_on
                brightness_pct: "{{ value | int }}"
                entity_id: light.night_stand
            range:
              - 0
              - 100
            step: 1
            thumb: default
            styles: |
              :host {
                {% if is_state(config.entity, "on") %}
                --color: rgb({{ state_attr(config.entity, "rgb_color") }})
                {% endif %}
              .tooltip {
                {% if is_state(config.entity, "off") %}
                display: none;
                {% endif %}
    type: tile
    features_position: bottom
    vertical: false
    tap_action:
      action: none
    icon_tap_action:
      action: more-info
    hide_state: true
    card_mod:
      style: |
        hui-card-features {
         transform: rotate(-90deg) !important;
         width: 140px;
         height: 130px;
          left: 10px;
  - features:
        entries:
          - type: slider
            tap_action:
                entity_id: light.pc_lights
            range:
              - 0
              - 100
            step: 1
            thumb: default
            styles: |
              :host {
                {% endif %}
              .tooltip {
                display: none;
                {% endif %}
    type: tile
    vertical: false
    tap_action:
      action: none
    icon_tap_action:
      action: more-info
    hide_state: true
    card_mod:
      style: |
        hui-card-features {
         width: 140px;
         height: 130px;
          left: 10px;
  - features:
        entries:
          - type: slider
            tap_action:
                entity_id: light.tv_lights
            range:
              - 0
              - 100
            step: 1
            thumb: default
            styles: |
              :host {
                {% endif %}
              .tooltip {
                display: none;
                {% endif %}
    type: tile
    vertical: false
    tap_action:
      action: none
    icon_tap_action:
      action: more-info
    hide_state: true
    card_mod:
      style: |
        hui-card-features {
         width: 140px;
         height: 130px;
         left: 10px;
layout:
