Vertical stack card - GUI bug
Image of it not working
Image of it working as it should
Added the first section of the vertical stack, went to manual, pasted code, did the same for the second and pasted in the code, everything works fine.
The problem is when you edit it, it don’t give you the manual code gui for that section of the vertical card. I have tested this and seems very hit and miss, seems to be a bug with the gui.
Some sections of the vertical stack load the manual code gui, others don’t , all same code inside so no reason for it
Easy fix. Click “show code editor”. Done.
But I don’t want to see all the code in one go for all the sections in the vertical stack, I want to see it for just that one section of the vertical stack.
Bugs like this need to be fixed as it makes it easier for people that don’t fully get yaml.
