Have the same problem.
Only started after upgrading to 0.107.
I have tried reverting back to 0.106 and the vertical-stack-in-card was working fine, therefore this should be definitely a problem with the new upgrade.
Hey,
Can I ask how did you install the vertical-stack-in-card, i.e via HACS or differently?
So far, I had it downloaded and installed from github as a custom component and started noticing the error after upgrade to 0.107.
After this issue, I have tried installing the same card via HACS and it looks like the error has disappeared.
I’ve the same problem after upgrading to 2021.3.4. Tried to install it via HACS and locally, tested also all different versions how to reference to it via resources, but still get the error. Any ideas would be very much appreciated.
Have recently updated this card to v0.4 and my card used to be completely transparent but now isn’t. Any idea what code I need to use now to make it transparent again? I believe this change happened between v 0.3.1 to v0.3.2 and above but not 100% sure. My code is:
Did you find a solution?
I sat for hours trying to faciliate border-radius for custom:button-cards within a vertical-stack-in-card, but every time it gets overwritten to be 0px. No use trying with card_mod:… same result.
Annoying.
Thank you for your hints. ha-card-border-radius works within the card_mod…statement, but ofc it styles the enclosing stack-in-card, not the button-card itself. A pity!
Using the plain/builtin vertical-stack I have no problem styling the button-cards, but then I can’t get rid of the gap betweeen the cards, especially if I switch some off (with display: none) - the buttons are gone but their padding/margin/whatever remains. Old/known vertical-stack problem and maybe the reason for developing the vertical-stack-in-card in the first place…
And I had no luck with the transparent background either. Maybe I should start anew, placing my buttins within a layout-card or whatnot…
hmmm, the “card-mod” doesn’t even “bite”, if you place it direct under " -type: custom:button-card " ? , but ur right, getting rit of “gaps” is a pain …
… keep searching in the forum, then you might get more ideas, and hints … and as you and benm7 above, don’t provide any example (pic) of what you are trying to accomplice, it’s hard to suggest anything ! … might even be a " custom:paper-buttons-row " you are looking for, or a mix/merge of multiple cards(cards within cards within cards), depending how you wanna design your View
