I am trying to get two different cards to work in the vsic.
Here is my code - still shows up as two seperate items.
type: custom:vertical-stack-in-card
cards:
- type: entities
entities:
- entity: sensor.server_arraystatus
icon: mdi:server
- entity: sensor.server_arrayprotection
icon: mdi:server
- entity: sensor.server_cpu
icon: mdi:cpu-64-bit
- entity: sensor.server_memory
icon: mdi:memory
- entity: sensor.server_diskspace
icon: mdi:harddisk
- type: custom:bar-card
title_position: inside
align: center
padding: 4px
entities:
- entity: sensor.glances_cpu_used_2
title: CPU
- entity: sensor.glances_ram_used_percent_2
title: RAM
severity:
- value: 50
color: '#00ff0d'
- value: 70
color: '#f6ff00'
- value: 100
color: '#ff0000'
What is the proper way to add it - I see this from github
inside your ui-lovelace.yaml
resources:
- url: /local/vertical-stack-in-card.js?v=0.1.3
type: js
but from the HACS install:
-url: /hacsfiles/vertical-stack-in-card/vertical-stack-in-card.js
type: module
I’m using the url from hacs but am seeing this in logs
hacsfiles/vertical-stack-in-card/vertical-stack-in-card.js:176:0 NotSupportedError: ‘vertical-stack-in-card’ has already been defined as a custom element
Same error if I point the url to /local/community which is where the folder is actually at.
