Hi everyone,
I’m having an issue getting vertical-stack working in HA. I keep getting an error message in my yaml file:
Configuration errors detected:
Unknown type: vertical-stack
This is the code in question:
title: Battery 2
cards:
- type: custom:stack-in-card
keep:
margin: false
box_shadow: false
background: false
cards:
- type: grid
square: false
columns: 1
cards:
- type: markdown
content: >-
<center>Time: <b><font color=#3090C7>{{
states('sensor.bms1_total_runtime_formatted') | upper
}}</font>
- type: grid
square: false
columns: 3
cards:
- type: markdown
content: >-
<center>Charge: <b>{% if states('switch.bms1_charging')
== 'on' %} <font color=#41CD52>{{
states('switch.bms1_charging') | upper }}</font> {% else %}
<font color=red>{{ states('switch.bms1_charging') | upper
}}</font> {% endif %}
- type: markdown
content: >-
<center>Discharge: <b> {% if
states('switch.bms1_discharging') == 'on' %} <font
color=#41CD52>{{ states('switch.bms1_discharging') | upper
}}</font> {% else %} <font color=red>{{
states('switch.bms1_discharging') | upper }}</font> {% endif
- type: markdown
content: >-
<center>Balance: <b> {% if
states('switch.bms1_balancing') == 'on' %} <font
color=#41CD52>{{ states('switch.bms1_balancing') | upper
states('switch.bms1_balancing') | upper }}</font> {% endif
keep:
margin: false
box_shadow: false
background: false
cards:
- type: grid
square: false
columns: 2
cards:
- type: markdown
content: >-
<center><b><font color=#41CD52 size=6>{{
states('sensor.bms1_battery_voltage') }} V</font></b><br>
Battery Power: <font color=#41CD52>{{
states('sensor.bms1_battery_power') }} W</font><br> Battery
Capacity: <font color=#41CD52>{{
states('number.bms1_battery_capacity_total_settings') }}
Ah</font><br> Cycle Capacity: <font color=#41CD52>{{
states('sensor.bms1_battery_capacity_total_charging_cycle') }}
Ah</font><br> Ave. Cell Vol.: <font color=#41CD52>{{
states('sensor.bms1_cell_average_voltage') }} V</font><br>
Balance Cur.: <font color=#41CD52>{{
states('sensor.bms1_balancing_current') }} A</font><br>
Battery T1: <font color=#41CD52>{{
states('sensor.bms1_temperature_sensor_1') }} °C</font>
- type: markdown
content: >-
states('sensor.bms1_battery_current') }} A</font></b><br> Remain
Battery: <font color=#41CD52>{{
states('sensor.bms1_battery_capacity_state_of_charge') }} %</font><br> Remain
states('sensor.bms1_battery_capacity_remaining') }} Ah</font><br>
Cycle Count: <font color=#41CD52>{{
states('sensor.bms1_charging_cycles') }}</font><br> Delta
states('sensor.bms1_cell_delta_voltage') }} V</font><br> MOS
Temp.: <font color=#41CD52>{{
states('sensor.bms1_temperature_powertube') }}
°C</font><br> Battery T2: <font color=#41CD52>{{
states('sensor.bms1_temperature_sensor_2') }} °C</font>
keep:
margin: false
box_shadow: false
background: false
cards:
- type: grid
square: false
columns: 1
cards:
- type: markdown
content: <center><b>Cells
- type: grid
square: false
columns: 2
cards:
- type: markdown
content: >-
<center>01. {% if
states('sensor.bms1_cell_voltage_max_cell_number') == '1' %} <font
color="#3090C7">{{ states('sensor.bms1_cell_voltage_01') }}
V</font> {% elif states('sensor.bms1_cell_voltage_min_cell_number') ==
'1' %} <font color="red">{{
states('sensor.bms1_cell_voltage_01') }} V</font> {% else %}
{{ states('sensor.bms1_cell_voltage_01') }} V {% endif %}
states('sensor.bms1_cell_resistance_01') }} Ω <br>
02. {% if
states('sensor.bms1_cell_voltage_max_cell_number') == '2' %} <font
color="#3090C7">{{ states('sensor.bms1_cell_voltage_02') }}
'2' %} <font color="red">{{
states('sensor.bms1_cell_voltage_02') }} V</font> {% else %}
{{ states('sensor.bms1_cell_voltage_02') }} V {% endif %}
states('sensor.bms1_cell_resistance_02') }} Ω <br>
03. {% if
states('sensor.bms1_cell_voltage_max_cell_number') == '3' %} <font
color="#3090C7">{{ states('sensor.bms1_cell_voltage_03') }}
'3' %} <font color="red">{{
states('sensor.bms1_cell_voltage_03') }} V</font> {% else %}
{{ states('sensor.bms1_cell_voltage_03') }} V {% endif %}
states('sensor.bms1_cell_resistance_03') }} Ω <br>
04. {% if
states('sensor.bms1_cell_voltage_max_cell_number') == '4' %} <font
color="#3090C7">{{ states('sensor.bms1_cell_voltage_04') }}
'4' %} <font color="red">{{
states('sensor.bms1_cell_voltage_04') }} V</font> {% else %}
{{ states('sensor.bms1_cell_voltage_04') }} V {% endif %}
states('sensor.bms1_cell_resistance_04') }} Ω <br>
05. {% if
states('sensor.bms1_cell_voltage_max_cell_number') == '5' %} <font
color="#3090C7">{{ states('sensor.bms1_cell_voltage_05') }}
'5' %} <font color="red">{{
states('sensor.bms1_cell_voltage_05') }} V</font> {% else %}
{{ states('sensor.bms1_cell_voltage_05') }} V {% endif %}
states('sensor.bms1_cell_resistance_05') }} Ω <br>
06. {% if
states('sensor.bms1_cell_voltage_max_cell_number') == '6' %} <font
color="#3090C7">{{ states('sensor.bms1_cell_voltage_06') }}
'6' %} <font color="red">{{
states('sensor.bms1_cell_voltage_06') }} V</font> {% else %}
{{ states('sensor.bms1_cell_voltage_06') }} V {% endif %}
states('sensor.bms1_cell_resistance_06') }} Ω <br>
07. {% if
states('sensor.bms1_cell_voltage_max_cell_number') == '7' %} <font
color="#3090C7">{{ states('sensor.bms1_cell_voltage_07') }}
'7' %} <font color="red">{{
states('sensor.bms1_cell_voltage_07') }} V</font> {% else %}
{{ states('sensor.bms1_cell_voltage_07') }} V {% endif %}
states('sensor.bms1_cell_resistance_07') }} Ω <br>
08. {% if
states('sensor.bms1_cell_voltage_max_cell_number') == '8' %} <font
color="#3090C7">{{ states('sensor.bms1_cell_voltage_08') }}
'8' %} <font color="red">{{
states('sensor.bms1_cell_voltage_08') }} V</font> {% else %}
{{ states('sensor.bms1_cell_voltage_08') }} V {% endif %}
states('sensor.bms1_cell_resistance_08') }} Ω <br></center>
- type: markdown
content: >-
<center>09. {% if
states('sensor.bms1_cell_voltage_max_cell_number') == '9' %} <font
color="#3090C7">{{ states('sensor.bms1_cell_voltage_09') }}
'9' %} <font color="red">{{
states('sensor.bms1_cell_voltage_09') }} V</font> {% else %}
{{ states('sensor.bms1_cell_voltage_09') }} V {% endif %}
states('sensor.bms1_cell_resistance_09') }} Ω <br>
10. {% if
states('sensor.bms1_cell_voltage_max_cell_number') == '10' %} <font
color="#3090C7">{{ states('sensor.bms1_cell_voltage_10') }}
'10' %} <font color="red">{{
states('sensor.bms1_cell_voltage_10') }} V</font> {% else %}
{{ states('sensor.bms1_cell_voltage_10') }} V {% endif %}
states('sensor.bms1_cell_resistance_10') }} Ω <br>
11. {% if
states('sensor.bms1_cell_voltage_max_cell_number') == '11' %} <font
color="#3090C7">{{ states('sensor.bms1_cell_voltage_11') }}
'11' %} <font color="red">{{
states('sensor.bms1_cell_voltage_11') }} V</font> {% else %}
{{ states('sensor.bms1_cell_voltage_11') }} V {% endif %}
states('sensor.bms1_cell_resistance_11') }} Ω <br>
12. {% if
states('sensor.bms1_cell_voltage_max_cell_number') == '12' %} <font
color="#3090C7">{{ states('sensor.bms1_cell_voltage_12') }}
'12' %} <font color="red">{{
states('sensor.bms1_cell_voltage_12') }} V</font> {% else %}
{{ states('sensor.bms1_cell_voltage_12') }} V {% endif %}
states('sensor.bms1_cell_resistance_12') }} Ω <br>
13. {% if
states('sensor.bms1_cell_voltage_max_cell_number') == '13' %} <font
color="#3090C7">{{ states('sensor.bms1_cell_voltage_13') }}
'13' %} <font color="red">{{
states('sensor.bms1_cell_voltage_13') }} V</font> {% else %}
{{ states('sensor.bms1_cell_voltage_13') }} V {% endif %}
states('sensor.bms1_cell_resistance_13') }} Ω <br>
14. {% if
states('sensor.bms1_cell_voltage_max_cell_number') == '14' %} <font
color="#3090C7">{{ states('sensor.bms1_cell_voltage_14') }}
'14' %} <font color="red">{{
states('sensor.bms1_cell_voltage_14') }} V</font> {% else %}
{{ states('sensor.bms1_cell_voltage_14') }} V {% endif %}
states('sensor.bms1_cell_resistance_14') }} Ω <br>
15. {% if
states('sensor.bms1_cell_voltage_max_cell_number') == '15' %} <font
color="#3090C7">{{ states('sensor.bms1_cell_voltage_15') }}
'15' %} <font color="red">{{
states('sensor.bms1_cell_voltage_15') }} V</font> {% else %}
{{ states('sensor.bms1_cell_voltage_15') }} V {% endif %}
states('sensor.bms1_cell_resistance_15') }} Ω <br>
16. {% if
states('sensor.bms1_cell_voltage_max_cell_number') == '16' %} <font
color="#3090C7">{{ states('sensor.bms1_cell_voltage_16') }}
'16' %} <font color="red">{{
states('sensor.bms1_cell_voltage_16') }} V</font> {% else %}
{{ states('sensor.bms1_cell_voltage_16') }} V {% endif %}
states('sensor.bms1_cell_resistance_16') }} Ω <br></center>
- type: entities
entities:
- entity: switch.bms1_balancing
- entity: switch.bms1_charging
- entity: switch.bms1_discharging
show_header_toggle: false
