Vertical stack problem - lovelace?!
Hello!
I have been strugling making these two cards in a vertical stack. Can anybody please.help me solving this.
indentera förformatterad text med 4 mellanslag
  - title: narvaro
    cards:
      - type: map
        aspect_ratio: 100%
        default_zoom: 8
         entities:
          - device_tracker.google_maps_xxxx
          - device_tracker.google_maps_yyyy
          - device_tracker.google_maps_zzzz
          - zone.home
          - zone.work
          - zone.fritidshus
          - zone.adress
          - zone.adress2
      - type: entities
        title: familjen
        entities:
Could you format your code using the </> button in the editor please? It makes it easier to see whether there are obvious syntax/indentation issues
As it shows up as a map and a entity card. I would like it to stack it vertically so it shows the same in different browsers. but when I try to use vertical-stack i dont seem to place it right ?!
I take it your first line was copied in error?
Also this isn’t a vertical stack, it’s just 2 cards.
Doc shows a vertical stack to be built this way:
- type: vertical-stack
  cards:
    - type: picture-entity
      entity: camera.demo_camera
      show_info: false
    - type: entities
      entities:
        - binary_sensor.movement_backyard
so you’d need to amend to make it look something like that:
title: Home
  - title: default_view
    icon: mdi:home
    cards:
        cards:
          - type: map
            aspect_ratio: 100%
            default_zoom: 8
             entities:
              - zone.home
              - zone.work
              - zone.fritidshus
              - zone.adress
              - zone.adress2
          - type: entities
            title: familjen
            entities:
            show_info: false
          - type: entities
            entities:
