First time using LED lighting. Bought a Gledopto controller as everyone here says it’s the best, but I’m having nothing but confusion. It’s a Gledopto GL-C-008 controller, has six wire connections.
The Gledopto controller has:
W C B G R V+
The BTF RGBVVT LED strip has:
12V W1 G R B W2
So I’m confused about which wires go into which holes in the Gledopto. I’m assuming:
V+ → 12V
B → B
G → G
R → R
But then I’m stumped on the W and C on the Gledopto, and the W1 and W2 on the LED strip.
Also very strange wire connections on the Gledopto. Not sure if I push, or if that slot is for a slotted screwdriver to turn.
Totally unrelated to your question. However, as one LED noob’s lesson… make sure as you are messing around you do NOT keep your LED string in it’s roll while you have it powered on. I keep this LED roll in the workshop as a reminder of what the fire department would have found… Good hunting!
Then you may need to swap the W1 and W2 connections to the LED strip as I don’t know which one is the warm white and which is the cold white without digging into it too far.
It is really simple.
You have an RGB+Warmwhite+Coldwhite strip, it means 5 different LEDs on your strip, wired separately. V+ or 12V is the common grund for all LEDs. The rest is for power supply for each. One “w” is for warm white (2200-2700 K) and the other ist for the cold white (6500 K) one. You cannot do any wrong if you mes them up (expect V+), you will just get weird colors
Can confirm using the BTF-Lighting 5050 RGBCCT which looks exactly like you have pictured.
12V → V+
W1 → W (Warm)
G → G
R → R
B → B
W2 → C
Also if this is you first lights in home assistant, the way to check is connect it to zigbee, go to the device in settings, instead of click the on off, click the device name itself. The popup window will have an RGB circle and a CCT circle. Click the CCT circle to slide between warm and cool to confirm.
