i am having a problem of very high disk storage consumption with my home assistant server as it is almost full , i have installed it in my laptop with 320gb HDD , ubuntu 16.04,
sometime back this consumption was full but after update of HA the space was emptied , but now there is no update and the storage is full .
please help , if i restart my system then it will not be able to start again .
I don’t think so.
Your log gets spammed with thousands of errors about the database.
I would first delete the home-assistant_v2.db and restart HA.
Then take a look at your logs and fix the errors that are shown.
You can also set the logger to a level that logs only warnings/errors.
