Hi I use a PI 4 with 4GB Ram and a M2 SSD to run home assistant. I just realised that the CPU utilisation with OS10 is significantly higher compared to 9.5. In 10 I have an average of 60% alternating between 30 & 80 every few seconds and memory around 60%. After I downgraded to 9.5 with all add-ons the same I get CPU around 20% and memory 35%.
Any thoughts or similar experience?
I found this out after my PI4 which is only passively cooled started rebooting due to heat problems. After I reverted to 9.5 everything is rock stable again.
