So I was trying to control my daikin AC (model FTKS25AXV1H/RKS25AXV1H) with esphome, but all daikin ir remote modules failed. I also tried the suggestion from there and used the arduino heatpumpir lib
but the AC did not respond
then I tried to do the steps here and tried to copy the remote manually:
it got recognised as a pronto protocol but the codes were all over the place. They were way too long and different each time.
I then tried another remote from a denon AVR and pressed the mute button. I found out that the code were all different.
What should I do next? can anyone help me to find the exact code to replicate?
After some tinkering, I used the IRremoteESP8266 library on a, well, esp8266 and discovered that it seems to use the DAIKIN64 protocol. I spammed multiple commands, which seem to decode the output 1/10 of all tries. I will continue to document my findings.
I also discovered that my remote seems to be a BRC52A62 by shear luck after googling the aircon model number and the term “ir code”.
Hey, I think I have the same problem as you, did you manage to fix it?
I tried ESPhome daikin protocols but couldn’t get them to work, so I installed Tasmota and set up Tasmota HRVAC integration, works just fine (DAIKIN64), however I get a lot of status desyncs and wonder if I can get better results with the right esphome driver
My ir sensor is 5V and 5V only. Attempting to use 3.3 would not work and results in garbage data.
Even if the voltage is correct, the issue is that the IR sensor might not reliability pick it up. Repeat multiple times until you got something expected.
The state is inverterted, send a ON results in a OFF
I dont care to install yet another MQTT broker and yet another thing to my stack, but it might not for you. I ultimately used tasmota as you said it worked, and it did
Hi. I’m running into the same issue. I was doing this project and got right up to the end, only to find that my Daikin model runs off DAIKIN64’s protocol as well, which isn’t natively supported by ESPHOME i think?
