service: cover.close_cover
entity_id: cover.galery_shutter
mode: single
This automation has been created with the tool. (An other automation with this tool works.)
“Run actions” of this automation makes this shutter move.
HA Overview shows the actual temperature of “climate.living_temperature_3” and it is above 23 (C).
The whole HA configuration is valid. (with KNX which is working properly).
The Numeric State Trigger will trigger only when the value crosses the threshold. In your example, it will trigger only at the moment when the value of current_temperature increases above 23. It will not continue to trigger if the value continues to increase above 23.
If it’s currently above 23, the Numeric State Trigger will not trigger until the temperature decreases below 23 and then rises above it.
