I’ve just configured Frigate using the Integration and the Frigate Add-On with my Reolink POE doorbell. Everything is working fine apart from a very strange issue with trying to activate recordings. When I toggle it on, it toggles back off by itself a couple of seconds later!
When I try to access recordings in the Frigate Add-On it says to make sure recordings are enabled but I’m pretty sure it’s configured correctly in the config:
Here is my config:
mqtt:
host: 192.168.1.52
port: 1883
topic_prefix: frigate
client_id: frigate
user: mqtt-user
password: Password
stats_interval: 60
go2rtc:
streams:
reolink:
- rtsp://admin:[email protected]:554/h264Preview_01_sub
- ffmpeg:rtsp://admin:[email protected]:554/h264Preview_01_sub#audio=pcm#audio=volume
## THIS PREVENTS THE AUDIO COMING OUT FROM THE DOORBELL SOUNDING MUFFLED
ffmpeg:
bin: ffmpeg
volume: "-af \"volume=30dB\""
cameras:
reolink:
ffmpeg:
inputs:
## CHANGE RTSP USERNAME AND PASSWORD
- path: rtsp://admin:[email protected]:554/h264Preview_01_sub
roles:
- detect
- record
output_args:
record: preset-record-generic-audio-copy
zones:
reolink_zone:
coordinates: 0,480,800,480,543,323,362,329,0,61
motion:
mask:
- 613,309,800,361,800,0,275,0,297,339
