viCare add datapoints / entities for Vitocal 262-A
I’ve been using the Viessmann Vitocal 262-A T2H-R290 for a few weeks now. The Home Assistant integration has been successfully installed and the device has been integrated accordingly. Everything is working fine so far. Unfortunately, however, the most important information for me is not displayed.
  • Hot water temperature
  • Top cylinder temperature
  • Middle cylinder temperature
  • Bottom cylinder temperature
  • Status of external heat generator
  • current power consumption.
It seems that the data points are available and they’re basic. Is it possible to include the query of the data points for the above-mentioned system in the viCare integration?
Hi, did you get these data somehow to HA? Or is this still not available? I think to buy the Vitocal 262 too, but without reading the water temp it is a bit frustrating…
