Vicare Viesmann install, choose the second of two devices
I have two Viessmann device, but you only offer one when installing. Does anyone have an idea?
Of course, the one I don’t want to see.
One device would be enough, but I don’t want to see what it throws up, but the other one.
If I retrieve it, it shows that I have a device with a “0” and a “1” ID, and I need “1”.
did you ever solve this? I have the same issue
Part.
I don’t use the factory one, but this one: GitHub - oischinger/ha_vicare: Home Assistant component for Viessmann Vitodata service In this, after installation, I rewrote the ID to 1 and then add the device and it already works.
I’m just about to start adding the other boiler.
There is already a test version out there that knows this.
