Hi All,
I am having trouble configuring VictoriaMetrics for storing long-term sensor data.
I am fairly new to HomeAssistant, possibly just missing some trivial things.
I use a HomeAssistantOS installation (KVM on Linux) which is accessible on the local network as homeassistant.local (on IP 192.168.1.114)
The main problem is that I think I have configured everything correctly, but the Explore function of Grafana shows “No Data” when I try to query the default “value” from “measurement” query.
What I have done so far:
Installed the the VictoriaMetrics Addon via the UI
Configuration:
retention: 99y
additionalArguments: ""
enableHTTPAuth: false
username: ""
password: ""
enablePrometheusScrape: false
prometheusScrapeHTTPS: false
prometheusScrapeInterval: 20s
prometheusScrapeTimeout: 15s
longelivedToken: ""
homeassistantUrl: ""
port exposed: 8428 (default)
Installed the InfluxDB integration
By configuring it in configuration.yaml using the (File editor) plugin.
# Victoria Metrics via the InfluxDB interface
influxdb:
api_version: 1
# homeassistant.local
host: 192.168.1.114
port: 8428
max_retries: 3
measurement_attr: entity_id
tags_attributes:
- friendly_name
- unit_of_measurement
ignore_attributes:
- icon
- source
- options
- editable
- min
- max
- step
- mode
- marker_type
- preset_modes
- supported_features
- supported_color_modes
- effect_list
- attribution
- assumed_state
- state_open
- state_closed
- writable
- stateExtra
- event
- friendly_name
- device_class
- state_class
- ip_address
- device_file
- unitOfMeasure
include:
domains:
- sensor
- binary_sensor
- light
- switch
- cover
- climate
- input_boolean
- input_select
- number
- lock
- weather
exclude:
entity_globs:
- sensor.clock*
- sensor.date*
- sensor.glances*
- sensor.time*
- sensor.uptime*
- sensor.dwd_weather_warnings_*
- weather.weatherstation
- binary_sensor.*_smartphone_*
- sensor.*_smartphone_*
- sensor.adguard_home_*
- binary_sensor.*_internet_access
Restarted Hass
In order for the InfluxDB setting to take effect.
Afterwards, I have checked the homeassistant.log file with the File editor and I did NOT see anything related to InfluxDB or VictoriaMetrics in it.
How could I investigate / debug what is happening ?
Any help is appreciated !
