Hallo together,
I´d like to send the Victron Tank-Values (Sensor I4 = ID 20) to HA and try to use the following
sensor-values in modbus.yaml (with Multiplus-values does it work correctly !)
- name: Tank Capacity
slave: 20
register: 3001
data_type: uint32
scale: 10000
precision: 1
- name: Tank Fluid Type
slave: 20
register: 3002
data_type: uint16
scan_interval: 10
lazy_error_count: 3
- name: Tank Level
slave: 20
register: 3004
data_type: uint16
scan_interval: 10
lazy_error_count: 3
- name: Tank Remaining Fluid
slave: 20
register: 3005
data_type: uint32
scan_interval: 10
lazy_error_count: 3
- name: Tank Status
slave: 20
register: 3007
data_type: uint16
scan_interval: 10
lazy_error_count: 3
Where are my mistakes ???
Thank you very much
