Hello, I’ve been using the vicare integration for about 6 months now and I’ve noticed that I keep having errors in the log. is there something to fix?
Logger: homeassistant.helpers.entity
Quelle: helpers/entity.py:951
Erstmals aufgetreten: 03:24:32 (1 Vorkommnisse)
Zuletzt protokolliert: 03:24:32
Update for number.e3_vitodens_200_0821_verschiebung_der_heizkurve fails
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 467, in _make_request
six.raise_from(e, None)
File "<string>", line 3, in raise_from
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 462, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.12/http/client.py", line 1423, in getresponse
response.begin()
File "/usr/local/lib/python3.12/http/client.py", line 331, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.12/http/client.py", line 292, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/local/lib/python3.12/socket.py", line 707, in readinto
return self._sock.recv_into(b)
File "/usr/local/lib/python3.12/ssl.py", line 1252, in recv_into
return self.read(nbytes, buffer)
File "/usr/local/lib/python3.12/ssl.py", line 1104, in read
return self._sslobj.read(len, buffer)
TimeoutError: The read operation timed out
File "/usr/local/lib/python3.12/site-packages/requests/adapters.py", line 486, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 799, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.12/site-packages/urllib3/util/retry.py", line 550, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.12/site-packages/urllib3/packages/six.py", line 770, in reraise
raise value
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 715, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 469, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 358, in _raise_timeout
raise ReadTimeoutError(
urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='api.viessmann.com', port=443): Read timed out. (read timeout=31)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 951, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1270, in async_device_update
await hass.async_add_executor_job(self.update)
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/vicare/number.py", line 278, in update
self._attr_native_value = self.entity_description.value_getter(
File "/usr/src/homeassistant/homeassistant/components/vicare/number.py", line 59, in <lambda>
value_getter=lambda api: api.getHeatingCurveShift(),
File "/usr/local/lib/python3.12/site-packages/PyViCare/PyViCareUtils.py", line 55, in feature_flag_wrapper
return wrapper(*args, **kwargs)
File "/usr/local/lib/python3.12/site-packages/PyViCare/PyViCareUtils.py", line 48, in wrapper
return func(*args, **kwargs)
File "/usr/local/lib/python3.12/site-packages/PyViCare/PyViCareHeatingDevice.py", line 557, in getHeatingCurveShift
return self.service.getProperty(f"heating.circuits.{self.circuit}.heating.curve")["properties"]["shift"][
File "/usr/local/lib/python3.12/site-packages/PyViCare/PyViCareCachedService.py", line 24, in getProperty
data = self.__get_or_update_cache()
File "/usr/local/lib/python3.12/site-packages/PyViCare/PyViCareCachedService.py", line 42, in __get_or_update_cache
data = self.fetch_all_features()
File "/usr/local/lib/python3.12/site-packages/PyViCare/PyViCareService.py", line 70, in fetch_all_features
return self.oauth_manager.get(url)
File "/usr/local/lib/python3.12/site-packages/PyViCare/PyViCareAbstractOAuthManager.py", line 37, in get
response = self.__oauth.get(f"{API_BASE_URL}{url}", timeout=31).json()
File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 602, in get
return self.request("GET", url, **kwargs)
File "/usr/local/lib/python3.12/site-packages/authlib/integrations/requests_client/oauth2_session.py", line 109, in request
return super().request(
File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 589, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 703, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.12/site-packages/requests/adapters.py", line 532, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPSConnectionPool(host='api.viessmann.com', port=443): Read timed out. (read timeout=31)
Logger: homeassistant.components.sensor
Quelle: helpers/entity_platform.py:1001
Integration: Sensor (Dokumentation, Probleme)
Erstmals aufgetreten: 03:24:31 (1 Vorkommnisse)
Zuletzt protokolliert: 03:24:31
Updating vicare sensor took longer than the scheduled update interval 0:00:30
type or paste code here
