Hello everyone,
Hope you can help me, I’m running into some issues with the UI not rendering properly when any view/tab is first loaded.
However, if I switch tabs and return, it normally loads correctly, resizing the window also causes it to layout correctly, most of the time.
If I refresh the page the layout breaks again.
This happens on Windows and Linux, with both the latest versions of Firefox (my default) and Chromium.
I’ve tried:
- Nuking my cache
- Clear cookies
- Updating the Docker container (ghcr.io/home-assistant/home-assistant:stable)
- Private mode,
- Developer mode with cache disabled
All the resources load properly, the console doens’t log any errors or failed requests.
Does anyone have any other stuff I can try to make this work?
Or if there’s any other info I can provide to help diagnose this issue.
Details:
- Home Assistant 2023.9.3
- Frontend 20230911.0 - latest
- Unraid 6.12.3
- Docker 20.10.24
- Architecture: x86_64
- CPUs: 40
- Total Memory: 128GB
