Vikunja is an Open-Source, self-hosted To-Do list application for all platforms.
Homepage: https://vikunja.io/
API Docs: https://try.vikunja.io/api/v1/docs
Github name: go-vikunja
Or even just a Vikunja add-on to start with? This looks like some really polished software, much better than other stuff which is available for to-do lists, and I expect many people would use it if it were able to be run alongside Home Assistant.
Is there someone who can help me to make this happen?
+1 for an integration
Hey,
I created one. GitHub - Craftoncu/hacs-vikunja-integration: Embed your Vikunja Tasks into HomeAssistant
But right now it isn’t possible to mark a task as resolved in home assistant. Its due hass logic I don’t understood until now. I’m trying to fix it soon.
Pull requests are very welcome!
can you have HA create tasks in vikunja w/ this integration?
Id have some automations based on triggers…etc create some todos or is this just pulling in only?
Is this supposed to only show the projects or each task as well?
I’m using CalDAV to sync tasks with Vikunja. This works, but it only sync the last created project. This doesn’t work for me I’ve got a task list for ‘daily tasks’ that I’d like to sync and some other projects that I don’t want to sync (or better: don’t want to show by default).
I think instead of creating a Vikunja integration, we should focus on the more versatile CalDAV integration and on improving tasks list in HA.
See CalDAV
When using /principals//, HA only syncs the last created project. The other endpoints don’t work at all. I’ll look for/create an issue on their repo as well, maybe they can help. I haven’t looked into the CalDAV specs yet.
