Vim1s ble5
Hello, I have recently installed HA on a WIM1S since it is a cheap SBC including a BT5 chip from Ampak. The BT built in device was not recognized immediately. So I have installed Bluez and it got recognized. I did not test the integration with HA certified BLE devices but aparently it should work with HA. Does somebody have some background with the WIM1S connecting to BLE devices. Thanks in advance. Guy
Hello guideon,
I think I have the same issue as you had (bluethoot is not configured properly) . I tried to install bluez using following command: sudo apt install bluez
but I always get the message: bash: sudo: command not found
How did you install Bluez on your Vim1s?
Thank you in advance for your support.
Kind Regards
Alexander
Hi Alexander, I finally got it working, you need to connect to home assistant using ssh and type sudo apt-get install bluez.
There is also a link for this:
bluetooth - Installing Bluez 5.44 onto Raspbian? - Raspberry Pi Stack Exchange. Regards Guy
