Hi, I have 5 vimar 14592.0 integrated in HA with conbee II and zigbee2mqtt, all working perfectly until I upgraded zigbee2mqtt to the latest release 1.33. 2, now on the interface of zigbee2mqtt, the 5 vimar switches work, I see their status and can change it without any problem, only on HA I don’t see their status and I can’t even change it (I attach two screenshot, one for zigbee2mqtt interface in which you can see the correct status, and the presence of button switch to change the status, and one for the home assisntance intervace, in which you are able to see that is showed as “disconnect” an no actions available to change the status), they appear as devices, if I change the name on zigbee2mqtt the name also updates on HA, but there is no way to change\see the status.
I have already tried removing the MQTT integration on HA and reinstalling it, unfortunately without success.
Has this happened to anyone before?
Thank you very much!
Note: all other zigbee devices (occupancy, temp, luminosity sensors) work without problems, I see them correctly on HA
