Vimar By-Me / By-Web integration
I added position options for covers now - but my guess is, that 0 and 100% is on the wrong side. let me know :wink:
I also tried to add the missing knx devices you listed above as switches and sensors.
@Nicola_Trussardi: Yes - I totally forgot: of course you need a computer - like a raspberry - to run home-assistant. I thought you asked, if you would need a raspberry additionally to have access to the vimar bus. so user pod is right.
I have not yet been able to load the latest version but I have looked at the “cover.py” file.
and … you’re right. the right way is:
fully open = 0%
fully closed = 100%
—EDIT—
I loaded the new version but it returns this error when I try to set the shutters to a certain opening
ERR
Thanks for the report. Should be fixed.
My python validator is currently not working… thus all those errors.
ok. in fact I did the update and it stopped detecting the shutters with the percentage command. while the simple ones (only up and down) still work.
red: percentage controll
green: only up&down
Any error messages?
yes…
this:
err2
and this:
2020-09-25 09:58:29 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/update_coordinator.py", line 118, in _handle_refresh_interval
    await self.async_refresh()
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/update_coordinator.py", line 192, in async_refresh
    update_callback()
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 296, in async_write_ha_state
    self._async_write_ha_state()
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 322, in _async_write_ha_state
    attr.update(self.state_attributes or {})
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/cover/__init__.py", line 204, in state_attributes
    current = self.current_cover_position
  File "/home/homeassistant/.homeassistant/custom_components/vimar_platform/cover.py", line 64, in current_cover_position
    return 100 - self.get_state('position')
TypeError: unsupported operand type(s) for -: 'int' and 'str'
I tried to open and close the shutters. the command is received correctly but home assistant does not update the status and reports the entity as disabled
uploaded a new version.
@pod in regards of the thermostats: do yours work now as expected? switching between heating, cooling and off mode?
Hi guys, first of all i have to congrat with you all, really great job! I buyed a Pi4 and tried to installa HA, configured Vimar and…it worked!!! (it took me almost 4 hours to do :rofl: first time for me with a Raspberry) Thanks a lot, i can control lights and thermostats! I also linked for Alexa and voice commands for light works great!
I’m trying to understand how it works, but seems all good…the only problem i have is that i can’t see controls of roller shutters, i can’t see in the list.
And also in the Vimar By Web i had some “scenario” (switch on all light on first floor, shitch off all lights, all roller shutters up, all roller shutters down) and they don’t work anymore (i tried to update again in the By Me the database without success…i see that scenario in the list of HA (switch.off_luci for example which should turn off all lights) but they don’t work, and now also in the Vimar webpage (or app)
Now i asked my electrician to send me the XML of my house and i will try to reinstall in the Vimar Server, let’s hope!
Hello
I loaded the latest version and now the thermostats and shutters seem to be working correctly.
Only one thermostat, the external one, is not detected correctly. I think because instead of using the internal probe it uses an external one.
I am attaching the attributes below:
external thermostat, not recognized
Row000005: '22734','forzatura off','-1','0'
Row000006: '22736','allarme_massetto','-1','0'
Row000007: '22738','regolazione','-1','0'
Row000008: '22742','modalita_fancoil','-1','0'
Row000009: '22744','velocita_fancoil','-1','0'
Row000010: '22746','funzionamento','-1','6'
Row000011: '22754','setpoint','-1','20.00'
Row000012: '22763','temporizzazione','-1','1'
Row000013: '22775','temperatura_misurata','-1','15.10'
Row000014: '22780','stato_boost on/off','-1','0'
Row000015: '22781','stato_principale_condizionamento on/off','-1','0'
Row000016: '22782','stato_principale_riscaldamento on/off','-1','0'
Row000017: '23448','uscita4','-1','non_utilizzata'
Row000018: '23449','uscita3','-1','non_utilizzata'
Row000019: '23450','uscita2','-1','non_utilizzata'
Row000020: '23451','uscita1','-1','non_utilizzata'
Row000022: '77148','T1','-1',''
Row000023: '77149','T2','-1',''
Row000024: '77150','T3','-1',''
garage thermostat, recognized (for comparison)
Row000069: '61608','forzatura off','-1','0'
Row000070: '61610','allarme_massetto','-1','0'
Row000071: '61612','regolazione','-1','2'
Row000072: '61616','modalita_fancoil','-1','0'
Row000073: '61618','velocita_fancoil','-1','0'
Row000074: '61620','funzionamento','-1','6'
Row000075: '61628','setpoint','-1','40.00'
Row000076: '61636','temporizzazione','-1','1'
Row000077: '61647','temperatura_misurata','-1','22.80'
Row000078: '61650','stato_boost on/off','-1','0'
Row000079: '61651','stato_principale_condizionamento on/off','-1','0'
Row000080: '61652','stato_principale_riscaldamento on/off','-1','0'
Row000081: '62460','uscita4','-1','non_utilizzata'
Row000082: '62461','uscita3','-1','non_utilizzata'
Row000083: '62462','uscita2','-1','non_utilizzata'
Row000084: '62463','uscita1','-1','non_utilizzata'
Row000085: '77253','T1','-1',''
Row000086: '77254','T2','-1',''
Row000087: '77255','T3','-1',''
errore in HA
2020-09-29 11:02:00 DEBUG (SyncWorker_62) [custom_components.vimar_platform.vimarlink] get_remote_devices started - from 0 to 300
2020-09-29 11:02:01 WARNING (SyncWorker_62) [custom_components.vimar_platform.vimarlink] Unknown object returned from web server: CH_HVAC / Esterno - Clima
2020-09-29 11:02:01 DEBUG (SyncWorker_62) [custom_components.vimar_platform.vimarlink] Unknown object has states: {'forzatura off': {'status_id': '22734', 'status_value': '0', 'status_range': ''}, 'allarme_massetto': {'status_id': '22736', 'status_value': '0', 'status_range': 'min=0|max=1'}, 'regolazione': {'status_id': '22738', 'status_value': '0', 'status_range': ''}, 'modalita_fancoil': {'status_id': '22742', 'status_value': '0', 'status_range': 'min=0|max=1'}, 'velocita_fancoil': {'status_id': '22744', 'status_value': '0', 'status_range': 'min=0|max=100'}, 'funzionamento': {'status_id': '22746', 'status_value': '6', 'status_range': ''}, 'setpoint': {'status_id': '22754', 'status_value': '20.00', 'status_range': 'min=-273|max=670760'}, 'temporizzazione': {'status_id': '22763', 'status_value': '1', 'status_range': 'min=0|max=65535'}, 'temperatura_misurata': {'status_id': '22775', 'status_value': '14.40', 'status_range': 'min=-273|max=670760'}, 'stato_boost on/off': {'status_id': '22780', 'status_value': '0', 'status_range': 'min=0|max=1'}, 'stato_principale_condizionamento on/off': {'status_id': '22781', 'status_value': '0', 'status_range': 'min=0|max=1'}, 'stato_principale_riscaldamento on/off': {'status_id': '22782', 'status_value': '0', 'status_range': 'min=0|max=1'}, 'uscita4': {'status_id': '23448', 'status_value': 'non_utilizzata', 'status_range': 'principale_riscaldamento=0|principale_condizionamento=0|boost_riscaldamento=0|boost_condizionamento=0'}, 'uscita3': {'status_id': '23449', 'status_value': 'non_utilizzata', 'status_range': 'principale_riscaldamento=0|principale_condizionamento=0|boost_riscaldamento=0|boost_condizionamento=0'}, 'uscita2': {'status_id': '23450', 'status_value': 'non_utilizzata', 'status_range': 'principale_riscaldamento=0|principale_condizionamento=0|boost_riscaldamento=0|boost_condizionamento=0'}, 'uscita1': {'status_id': '23451', 'status_value': 'non_utilizzata', 'status_range': 'principale_riscaldamento=0|principale_condizionamento=0|boost_riscaldamento=0|boost_condizionamento=0'}}
Another problem concerns the scenarios created by vimar.
The scenarios are recognized by HA as “switches” but in reality, for the Vimar server, they are single impulses. When you try to activate a scenario in HA, nothing happens and it remains blocked on ON.
scen1
Attributes below:
Row000001: 'ID','NAME','STATUS_ID','CURRENT_VALUE'
Row000002: '229','_DPAD_DBCONSTANT_VIMAR_BYME_TRIGGEROBJECT_VIDEOMESSAGE_UNHANDLED','-1','0'
Row000003: '265','_DPAD_DBCONSTANT_VIMAR_BYME_TRIGGEROBJECT_SENSORS_HUMIDITY_ALARM','-1','0'
Row000004: '270','_DPAD_DBCONSTANT_VIMAR_BYME_TRIGGEROBJECT_SAI2_LOG_ALARM','-1','1'
Row000005: '1160','indice','-1','9'
Row000006: '1161','comando','-1','1'
Row000007: '31561','_DPAD_PRODUCT_VIMARBYME_CERTIFICATE_TRIGGER','-1','0'
Unfortunately I haven’t had time yet to test the knx components you have integrated. I will do it as soon as possible.
I see - I will add CH_HVAC next. it seems they do have the same attributes.
about the scenes - you are right. I added them as switches - didn’t use them so far but only just now saw, that there is a platform for scenes already in hass - i’ll have a look at that as well.
Hello everybody. Thanks for what you do. I am new to this world. anyway, I have a system Vimar by me but with web server 01946 (light version) version 2.6. I bought a raspberry PI4 8gb and installed home assistant 64bit, but I cannot install the vimar integration. Can you kindly post a video for all beginners like me? Thanks a lot anyway. I just can’t. This is the error I find
Logger: homeassistant.setup
Source: custom_components/vimar_platform/init.py:118
First occurred: 21:18:10 (1 occurrences)
Last logged: 21:18:10
Error during setup of component vimar_platform
File “/usr/src/homeassistant/homeassistant/setup.py”, line 213, in _async_setup_component
result = await task
File “/config/custom_components/vimar_platform/init.py”, line 118, in async_setup
raise PlatformNotReady
homeassistant.exceptions.PlatformNotReady
Please help me. Im becoming crazy
I am not sure if this integration will work with 01946 - as far as I know we only tested it on 01945.
the PlatformNotReady exception is thrown when the login to the webserver does not work properly. This could be either an invalid url/user or password - or the login process to the web server light version is different.
how does your vimar_platform part of the configuration.yaml look like? did you check the example configurations on the github page: https://github.com/h4de5/home-assistant-vimar#problems-with-ssl-connection ?
Good morning. Thanks for the reply. I tried to insert all the “vimar platform” configurations including the http one, but nothing. I’ll try to install everything again, even raspberry (where I had some problems and maybe the problem is him. Maybe?).
Here’s what happened to me
  1. install Home assistant: OK
  2. install file editor: OK
  3. I install samba: problem
    In the configuration I also entered 192.168.1.0/24 as “allow_hosts” but I can’t find the 192.168.1.xy network where the raspberry is located. I tried to look for it also with \ 192.168.1.xy on explorer but nothing. If I then look in the samba logs I find “Samba name server HOMEASSISTANT is now a local master browser for workgroup WORKGROUP on subnet 172.30.32.1”. what is it? why this? Then I saw in File editor - network status home assistant Network status that “Your address: 172.30.32.2 - Listening address: http://0.0.0.0:8099 - HASS API address: http: // supervisor / homeassistant / api /. Why? How can I solve?
    4.Install duckdns: problem
    I create the duckdns address, insert the token and the duckdns address in the raspberry-duckdns configurator and then on my router I open port 8123. Then, but I also have to open port 443. How do I do it? It is already associated with the vimar web server on its internal address 192.168.1.xx. How do I open port 443 on raspberry which has another internal address 192.168.1.xy. The modem won’t let me. So from external I access in http on raspeberry with duckdns 192.168.1.xy: 8123 but not in https. How can I do?
Can these problems cause the vimar platform to not work?
If I go to raspberry on integrations - entities I see this Invalid config message - The following integrations and platforms could not be set up: - [vimar_platform] (https://github.com/h4de5/home-assistant-vimar) Please check your config .
I kindly ask you to help me step by step
Thanks a lot
unfortunatelly I can’t really help you with the home-assistant setup itself. I have not setup Samba or duckdns for my installation, sorry. If the forum does not yield any help for you, you may try out other community support options here: https://www.home-assistant.io/help/
Grazie Comunque. Continuo a provare e se riesco a far funzionare tutto con il web server 01946, vi aggiorno. Ciao
Grazie molto :smiley:
the integration distinguishes now between normal switches and scenes
Hello.
I also tested the latest update and everything works very well. The scenarios work perfectly. And now it also recognizes the external thermostat that it did not recognize before. Great!
I noticed that when I go to deactivate the auxiliary heating this error comes out:
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/websocket_api/commands.py", line 143, in handle_call_service
    connection.context(msg),
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/core.py", line 1335, in async_call
    task.result()
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/core.py", line 1370, in _execute_service
    await handler.func(service_call)
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity_component.py", line 205, in handle_service
    self._platforms.values(), func, call, required_features
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/service.py", line 470, in entity_service_call
    future.result()  # pop exception if have
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 655, in async_request_call
    await coro
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/service.py", line 507, in _handle_entity_call
    await result
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/climate/__init__.py", line 526, in async_service_aux_heat
    await entity.async_turn_aux_heat_off()
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/climate/__init__.py", line 462, in async_turn_aux_heat_off
    await self.hass.async_add_executor_job(self.turn_aux_heat_off)
  File "/usr/lib/python3.7/concurrent/futures/thread.py", line 57, in run
  File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/climate/__init__.py", line 458, in turn_aux_heat_off
    raise NotImplementedError()
NotImplementedError
…still great work Andi!
according to the vimar docs, the aux heater is a read only attribute, so you can only see if the heater is activated or off - but cannot change it. Is this true or are you able to change the status using the vimar webserver?
