Viomi S9 (v18) - how do you deal with map reset issues?
Hi everyone
Some things in life just dont work as they suppose to =(
My Viomi S9 is resetting its map now and then. The map is in the cloud and I can select it from the app and restore it, but when vacuum starts, its checkes its position few times and then starts to draw a brand new map =( There must be an answer for it, but I have no idea what it is
Anyone using anything special in HA/elsewhere to make the maps work again without runnings through the new map creation cycle again?
Hi, I have the same problem.
I think it is independent from HA and related to the Viomi Slam algorithm. For me it happens more often if the dockingstation is in a small space and most of the area is not visible from there.
Have you fond a solution?
