Virgin Tivo integration not working
A couple of years ago I had my Virgin V6 Tivo integrated in HA - it worked fine. Recently I had to create a complete new installation, and my re-build can’t seem to access it. I have followed the installation guide, created the required folder and moved the required files in there, and added the required lines to my configuration file.
In the log I see:
Logger: homeassistant.components.media_player
Source: helpers/entity_platform.py:366
integration: Media Player (documentation, issues)
First occurred: 16:27:59 (1 occurrences)
Last logged: 16:27:59
Error while setting up virgintivo platform for media_player
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 366, in _async_setup_platform
    await asyncio.shield(awaitable)
  File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 58, in run
  File "/config/custom_components/virgintivo/media_player.py", line 230, in setup_platform
    hass.data[DATA_VIRGINTIVO].append(VirginTivo(extra[CONF_HOST], channels, tivo_id, extra[CONF_NAME],
                                                 force_hd_on_tv, guide, keep_connected))
  File "/config/custom_components/virgintivo/media_player.py", line 330, in __init__
    self.get_guide_channels()
  File "/config/custom_components/virgintivo/media_player.py", line 341, in get_guide_channels
    for channel in channels_data["channels"]:
TypeError: list indices must be integers or slices, not str
I’m running HA on a Raspberry Pi 400
  • Core 2024.12.5
  • Supervisor 2024.12.0
  • Operating System 14.1
  • Frontend 20241127.8
My configuration file looks like this:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
# Virgin TIVO
media_player:
  - platform: virgintivo
    tivos:
      1:
        host: 192.168.0.xxx *<removed for security>*
    tvchannellists:
      enable: True
Can anyone please enlighten me as to what I’m doing wrong?
I’m having the same trouble and the same errors with
  • Core 2025.1.0
  • Supervisor 2024.12.3
  • Frontend 20250103.0
Can anyone advise?
Okaaaaayyyy… Apparenty not, then.
A pity - it was a useful integration.
If nobody has this working now, should it be demised from HACS? Or do others have it working?
