Hey there… I have a zwave dry contact relay and a door sensor that I’ve been using on other platforms for a couple years. Now that I’m on HA, I was looking for some code that would make use of the relay and the open/closed contact.
Here is the URL with the code I found that I’m trying to use but I think it is incomplete: Options for Garage Door Opener?
This person said that Covers.yaml contains this:
covers:
garage_door_backup:
friendly_name: "Garage Door Backup"
value_template: "{{ is_state('binary_sensor.d32_garage_door_main_sensor', 'on') }}"
open_cover:
service: script.garage_door_open_backup
close_cover:
service: script.garage_door_close_backup
icon_template: >-
{% if is_state('binary_sensor.d32_garage_door_main_sensor', 'on') %}
mdi:garage-open
{% else %}
mdi:garage
{% endif %
And this other file called Scripts.yaml contains this code:
garage_door_open_backup:
alias: 'Garage Door Open'
sequence:
- service: script.garage_notify
- condition: state
entity_id: input_boolean.mode_armed
state: 'off'
- service: switch.turn_on
entity_id: switch.d12_garage_door_switch
- delay: 00:00:03
- service: switch.turn_off
- delay: 00:00:30
- condition: state
entity_id: binary_sensor.d32_garage_door_main_sensor
state: 'off'
- service: notify.gregg_pushover
title: 'Garage Door Failure'
message: 'The Garage Door did not open or there is an issue with a sensor'
garage_door_close_backup:
alias: 'Garage Door Close'
sequence:
- delay: 00:00:03
- delay: 00:00:30
- condition: state
state: 'on'
message: 'The Garage Door did not shut or there is an issue with a sensor'
garage_notify:
alias: 'Garage Notify'
sequence:
- condition: state
state: 'on'
title: 'The Alarm is On'
message: 'Cannot open the Garage Door while the Alarm is On'
Is there any way that I can combine the two and put them into a package so everything is together? I also don’t know what is missing - I think the template section is missing something but I don’t have enough experience with this code to know. Any info would be appreciated - or if there is another solution that just works with my type of setup, I’d open to using something else. Thanks in advance for any information anyone may have.
Thanks,
-Alli
